Old 07-20-2025, 11:37 PM   #1
Firechickenzz
Firechickenzz's Avatar
Default Idle screw thread sealant?
I was looking for vacuum leaks with carb cleaner and found the idle screws weren't sealing. What is the recommended fix? Is it time for a new base from Stromberg?
I put some Permatex aviation form a gasket on the threads and it has made an improvement.
Firechickenzz is offline   Reply With Quote
Old 07-21-2025, 12:34 AM   #2
deuce lover
deuce lover's Avatar
Default Re: Idle screw thread sealant?
I suggest you contact Uncle Max in UT.He is a member here a a pro when it comes to these Strombergs.
[email protected]
He is a Stromberg dealer.
Old 07-21-2025, 07:28 AM   #3
Terry,OH
Terry,OH's Avatar
Unless your using new idle mixture screws it could be old screws thread have been damaged and not the Carb base. Suggest using a NEW 10-32 machine screw thread it into the base and see how it fits the thread. Take the old mixture screws and try a new nut on the threads and see how it fits. There are two parts on the 97 that appear like the same parts on a 94: The idle air tubes and the idle mixture adjustment screws. Don't get them mixed up! they are very different.
Old 07-21-2025, 08:50 AM   #4
Firechickenzz
Well aware of the Idle Jets vs Idle mixture screws. I actually just replaced every brass part in the carb with the exception of the float and the butterflies. I detected the leak while running the new mixture screws.
Old 07-21-2025, 08:58 AM   #5
Tim Ayers
[email protected]
This is a Holley carb he is working on I believe.
Tim Ayers is online now   Reply With Quote
Old 07-21-2025, 11:21 AM   #6
Firechickenzz
Stromberg 97
Old 07-21-2025, 11:40 AM   #7
Tim Ayers
Originally Posted by Firechickenzz View Post
Stromberg 97
Ah, right. I'll stop posting now. I'm getting things all mixed up. LOL!
Old 07-21-2025, 02:09 PM   #8
signsup
Would wrapping the threads of the screw with very fine brass wire and then inserting be a possible solution?
signsup is offline   Reply With Quote
Old 07-21-2025, 05:04 PM   #9
51shoeboxer
Some of the Holley four-barrel carbs I've played with have a foam "doughnut" on each of the idle jets that seal them to the carburetor body.
51shoeboxer is offline   Reply With Quote
Old 07-21-2025, 10:01 PM   #10
aussie merc
aussie merc's Avatar
i got a new big stromy[genuine] and its the same 1 side ok the other that bad that wiggling it side ways varies the idle dramatically no response from stromberg tried grease etc even permatex on thread improved but not good 2 turns of thread tape got it into acceptable So much for a quality product RUN OUT OF THE BOX their words not mine NEVER AGAIN
aussie merc is offline   Reply With Quote
Old 07-22-2025, 08:21 AM   #11
Firechickenzz
Good to know. I was considering a new one down the road.
Old 07-22-2025, 08:31 AM   #12
deuce lover
Clive of Stromberg stands behind his product and will always make it right.Contact him if you have an issue. A friend here had an issue with an E Fire that was 1.5 yrs old. He replaced it with a new one and paid shipping plus the customs duty charge.We sent the defective one back after receiving the replacement.
Old 07-23-2025, 06:20 AM   #13
aussie merc
well clive from stromberg better look at someones Emails sent 3 no replies and nothing speaks louder than silence.
Old 07-23-2025, 06:45 AM   #14
Terry,OH
Terry,OH's Avatar
How about an O-ring and small washer under the spring. Hardware stores usually have a good assortment of the rings.
