Old 07-15-2025, 03:33 PM   #21
petehoovie
petehoovie's Avatar
Default Re: Q: 34 Ford Coupe RHD rear window regulator
Originally Posted by Lawrie View Post
This is my 34 3w that mercman is talking about,ex NZ car.
After getting back home in the 33 at the end of the month I will be away in the 34 for 3 or 4000 klms
Lawrie
Old 07-15-2025, 05:25 PM   #22
DavidG
DavidG's Avatar
Fordson and Lawrie,
Off topic, but worth knowing (to me) is what in the way of stamped numbers exist on your firewalls. Normally Canadian-made '33s and '34s have no patent plate (those are U.S. patents on the U.S. patent plates) and no body number plates. But they have the engine number stamped on the firewall.
Is that the case with your '34s?
Also "different" is that at least some of the '33-'34s sold in South Africa had the engine number stamped on the right frame rail rather than on the left side.
Old 07-16-2025, 11:07 PM   #23
Lawrie
Lawrie's Avatar
David, I will look when I’m back home, but my 33 has the number stamped on the left hand frame rail.
I just had a look.it’s a bit hard to see though. Where about do you thing the number would be stamped on the firewall
Lawrie
Old 07-17-2025, 01:12 AM   #24
DavidG
DavidG's Avatar
Near the center of the bottom portion of the sloped center section of the firewall. It is in addition to the number stamped on top of the chassis frame rail.
Old 07-17-2025, 01:24 AM   #25
Lawrie
Lawrie's Avatar
Thanks,
Trevor will know if they are stamped on,my 33 has an aftermarket tool box there so I can’t look at that.
Lawrie
Old 07-17-2025, 01:50 AM   #26
mercman from oz
mercman from oz's Avatar
The Body Number on Australian 1933 and 1934 Fords is still visible when fitted with the Accessory Tool Box. This is my 1934 Ford Phaeton.
Old 07-20-2025, 05:49 PM   #27
fordson
Well on my 34 there was definately no Body Number Plate or Patent Plate. My Engine number is also stamped on the left hand frame rail. But i was not aware of a number in the left hand slope of the fire wall. But my cars body has been worked on before and not exactly professional, body filler, resprayed etc. Although having cleaned that all up i cannot remember anything on the firewall. I will also come back to you David on that. I might be able to also ask a good South African Friend, who owns 2 roadsters 33/34, on the position of the engine numbers. There should not be a difference within the modelrange in South African Fords, i guess. They should have all been stamped the same way or position.
Randolf
fordson is offline   Reply With Quote
Old 07-20-2025, 06:00 PM   #28
fordson
The Number on the US Drivers side frame rail on my 34 SA Coupe. I am not sure if the frame / chassis belongs to my 3-Coupe body or if it comes from a donour car.
Old 07-20-2025, 06:33 PM   #29
petehoovie
petehoovie's Avatar
Old 07-20-2025, 09:43 PM   #30
DavidG
DavidG's Avatar
At some point in the car's past a new number (not either U.S. or Canadian for '34s) was stamped on your frame.
Old 07-21-2025, 02:43 PM   #31
fordson
Thank you David, my car is full of surprises!
Regards Randolf
Old 07-27-2025, 07:16 AM   #32
fordson
Originally Posted by DavidG View Post
Fordson and Lawrie,
Hi David, i checked with a good friend in South Africa who has a few Fords
(1933 - 39 roadster, coupes, etc.) never any 5 or 3 windows though.
His reply to my question was, that he has never seen or has had a body plate on the fords of that time period. The Vin Number is on the RHS ( drivers side ) frame rail, next to the steering box. Some vehicle bodys have the number in addition to the cowl, others not.
My car was at one stage restored or built up, the local South African Authorities have stamped a new VIN number on my LHS frame rail. The original VIN Nb. is probably still on the RHS frame rail, but covered in paint. If iam with my car in October i will have a closer look.
All very interesting.
Regards Randolf
