#21 | |
![]() Quote:
Very clever. I will employ that trick.
Archeo-Tech Priest of the Cult Mechanicus. |
#22 |
As I recall, Bonnie Parker (Bonnie and Clyde) was severely burned by battery acid from hip to ankle when she and Clyde were involved in a rollover accident. Not sure make or year of the car, but Clyde preferred Fords...
#23 |
When replacing the floor boards I put threadstock in each clinch nut in the subframe. The top of the threadstock was ground to a sharp point. This located the hole to drill. Went one at a time.
#24 |
When replacing the floor boards I put threadstock in each clinch nut in the subframe. The top of the threadstock was ground to a sharp point. This located the hole to drill. Went one at a time. I don’t believe there was a template to locate the holes at the factory.
#25 |
Oops
#26 |
#27 | |
![]() Quote:
#28 |
Yep
#29 | |
![]() Quote:
Tom, for what shipping from the US would cost you might do better to find round stock in Germany (#12 is 5.556 mm diameter) and buy a 12-24 die, do it yourself.
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! Last edited by JayJay; 07-20-2025 at 06:50 AM. |
#30 |
That is why I said "similar". I didn't know the correct size thread, I was just using that as an example to explain what All Thread/Thread Stock looked like for TomInCologne... Geez, so picky!
#31 |
Check.
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! |
#32 |
Thanks.
My floorboards fit, i was just curious what that word meant and then how to fit new holes. |
