Old 05-01-2025, 07:31 PM   #21
midgetracer
midgetracer's Avatar
Default Re: Looking for repro FORD script coil
I have this one if someone needs it. I have no use for it so $50 would be plenty. Just pm me if you can use it. Not sure if it works.
midgetracer is offline   Reply With Quote
Old 05-04-2025, 12:11 PM   #22
Bullrhider
Bullrhider's Avatar
I'll take you coil. Where shall I send payment?
Bullrhider
Bullrhider is offline   Reply With Quote
Old 05-04-2025, 01:25 PM   #23
midgetracer
I pm'd you the address.
Old 07-16-2025, 05:09 PM   #24
Doug in NJ
Doug in NJ's Avatar
I was using a coil like this for a long time, but last week it died - the secondary winding is open. Is there any possible way to repair it? Is that sleeve that holds the top in place soldered on? Or should I just toss it?
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
Old 07-16-2025, 06:03 PM   #25
alexiskai
alexiskai's Avatar
The amount of work to repair a coil is likely way out of proportion to its value. Remember the components are (best case) immersed in oil or (worst case) sealed in hardened epoxy.
Old 07-16-2025, 07:08 PM   #26
nkaminar
nkaminar's Avatar
Doug, Empty the can and put a new coil inside. Find a new coil that fits inside. I think most of the ones that you can buy from the dealers will fit.
Old 07-17-2025, 10:43 AM   #27
katy
katy's Avatar
What does the circled SP on the coil represent? I assume a manufacturer?
Old 07-17-2025, 11:35 AM   #28
alexiskai
alexiskai's Avatar
Ye Olde Standard Products (now Standard Motor Products)
Old 07-17-2025, 06:39 PM   #29
Gene F
Gene F's Avatar
"The originals generally had a permanently attached bracket. " - the one on my car is like this. (March 1928)
Old 07-19-2025, 12:12 PM   #30
Bullrhider
Bullrhider's Avatar
Is this repro coil still available?
Old 07-19-2025, 12:15 PM   #31
Bullrhider
Bullrhider's Avatar
Is your repro coil still available?
Old 07-19-2025, 12:49 PM   #32
Marshall V. Daut
I have one that I would also sell for $50 plus postage (probably under $10 in a small box), since that seems to be the going rate for these rare script coils on this website. There are no dents. I don't know if it works, but I have no reason to think it doesn't. $50 as is plus postage, working or not, rain or shine, pretty much cleaned to bare metal.
Marshall
Marshall V. Daut is offline   Reply With Quote
Old 07-19-2025, 01:39 PM   #33
alexiskai
alexiskai's Avatar
Most of the original coils I've seen will work when you get started but lose strength quickly as they heat up.
Old 07-19-2025, 02:10 PM   #34
jb-ob
2X Alex.
jb-ob is offline   Reply With Quote
