Old 07-04-2025, 02:24 PM   #21
Hot Rod Reverend
Hot Rod Reverend's Avatar
Default Re: 1955 Ford/Mercury 2dr Hardtop carpet suggestions?
Originally Posted by jk2257 View Post
Oh, they sat out for a few hours on a near 100 degree day. No amount of sun is going to cure bad stitching. The carpet I removed from the car was also ACC and had the same pucker/poor stitching.
"No amount of sun is going to cure bad stitching." I am going to borrow that quote. I used ACC for my 1955 Ford Club Sedan and discovered the same thing. The carpet itself is of a good quality but the fitment was downright horrible. I have quite a few pictures on my blog at HotRodReverend.com.
Lancaster, California
Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan!
Hot Rod Reverend is offline   Reply With Quote
Old 07-04-2025, 03:01 PM   #22
jk2257
Even in the advertising photos you can see how crooked the seam is! Thankfully the rest of the carpeting seems to fit well, but that transmission hump with the errant seam is pretty much inexcusable.
Years ago, I remember getting carpet from JC Whitney and even though it wasn't the best in regards to quality of materials, at least the seams were straight!
Just wanted to add: Reverend, thank you for posting your windshield install on your car, that helped a great deal in seeing what was wrong with the installation performed on my car.
jk2257 is offline   Reply With Quote
Old 07-05-2025, 02:12 PM   #23
56sedandelivery
56sedandelivery's Avatar
Could you use that seam tape that they use for laying house carpet? You could then cut the pucker out and use the tape to glue it together.
56sedandelivery is offline   Reply With Quote
Old 07-05-2025, 07:44 PM   #24
jk2257
Great idea!
I just need to make sure it'd stand up automotive temperatures, etc. Surely though there must be something similar for outdoor carpeting or turf?
Old 07-06-2025, 02:28 PM   #25
Hot Rod Reverend
You are very much welcome!
Old 07-06-2025, 08:12 PM   #26
KULTULZ
KULTULZ's Avatar
Post Re: 1955 Ford/Mercury 2dr Hardtop carpet suggestions?
Great idea!
There should be insulating mat under the carpet unless it was removed somewhere along the line.
KULTULZ is offline   Reply With Quote
