Old 07-01-2025, 01:41 PM   #1
KCW
Default 1930 Model A - stuck temp gauge bolt
Hi everyone -
I’m trying to replace my Model A temperature gauge. The bolt where it enter is stuck. Attached is a photo. I can’t get it to budge at all. I’m an amateur and was wondering if there are any tricks to remove it. I do have a portable torch I could use to heat it but thought that could be dangerous. Can I use the torch? If not, how to I remove the bolt?
Thank you!
KCW is offline   Reply With Quote
Old 07-01-2025, 02:54 PM   #2
Y-Blockhead
Y-Blockhead's Avatar
Default Re: 1930 Model A - stuck temp gauge bolt
Looks like the smaller fitting is pretty well rounded off. Are you going to be using the temperature gauge again?
If not, I think I would just cut off the lead and use a 6 pointed socked on the larger fitting to unscrew. JMO...
Old 07-01-2025, 05:11 PM   #3
Vern
Vern's Avatar
If you want to save the gauge, Don’t cut the lead going into the radiator neck. It’s a hollow tube that has a bulb on the end inside the neck. If you cut the tube you will have to get it repaired which is not cheap, but can be done.
If you run the car enough to heat it up, try to loosen it then.
If all fails, Williamson’s Instruments in Arkansas will possibly be able to do the repair to the gauge
Vern is offline   Reply With Quote
Old 07-01-2025, 05:18 PM   #4
Y-Blockhead
Exactly. That is why I asked him if he was going to use the gauge again.
Old 07-01-2025, 05:31 PM   #5
nkaminar
nkaminar's Avatar
Special wrenches are made for things like the nuts on the ends of the steel tubing for hydraulic brakes. These are heavy duty 6 point box end wrenches that have the end cut out so that it can be placed where there is a wire or tube coming out of the nut. Look for this special kind of wrench on McMaster Carr. Otherwise buy a new gauge and cut the wire and use a 6 point socket wrench.
Old 07-01-2025, 07:00 PM   #6
Bob C
Harbor Freight has line wrenches.
File Type: jpg Screenshot 2025-07-01 at 4.59.22 PM.jpg (12.3 KB, 12 views)
Old 07-01-2025, 08:09 PM   #7
J Franklin
J Franklin's Avatar
If it was put together with RED LockTite. you will need to heat the joint and use your muscles to remove it.
Old 07-02-2025, 06:50 AM   #8
nkaminar
nkaminar's Avatar
You may also want to use some penetrant.
Old 07-02-2025, 09:23 AM   #9
katy
katy's Avatar
Have you drained the cooling system?
Old 07-02-2025, 10:42 AM   #10
KCW
I tried the torch - didn’t budge! Not sure what my next move is. Maybe that wrench that was recommended?
Old 07-02-2025, 10:46 AM   #11
Phil Brown
Phil Brown's Avatar
Drain the water to below the part that your heating then try, no go.....get it hotter
Phil Brown is offline   Reply With Quote
Old 07-02-2025, 11:38 AM   #12
nkaminar
nkaminar's Avatar
The problem with the heat is that you are expanding the internal part which will make the threads tighter. Try the special wrench.
Old 07-02-2025, 11:47 AM   #13
Y-Blockhead
That small fitting is pretty well rounded off. That is why if he is not going to use the gauge again, I suggested cutting the lead and using a 6 sided socket on the larger fitting.
Old 07-02-2025, 12:03 PM   #14
Big hammer
Yep heating metals makes them expand………. Then when it cools it shrinks a teeny tiny bit………. Just what body men do with sheet metal, heat shrinking :-)
get a bigger hammer tap done
Old 07-02-2025, 06:47 PM   #15
CWPASADENA
CWPASADENA's Avatar
A while back, I was confronted with this same problem. I carefully filed down the flats on the hex part of the gland nut to the next smaller wrench size and used a line wrench. I did soak in penetrant for a few days before I tried to turn it.
I would be careful using heat because you may damage the capillary tube.
That is what I did.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 07-03-2025, 08:24 AM   #16
katy
katy's Avatar
Cut the tube, use a 6 point socket and remove the adapter from the water outlet. Get a new adapter to go w/the new temp gauge.
Old 07-03-2025, 03:30 PM   #17
ModelA29
ModelA29's Avatar
The heat/cool process if about getting enough expansion/contraction to break the bond of the corrosion. It's not like putting together pressed assemblies where a part goes in the freezer and you heat the other part so they can be easily assembled.
The problem with this type assembly is you have a hollow soft brass tube with a hex cut on it. It's a tapered thread so it seals by being firmly jammed into the other threads. A open end wrench just deforms the tube and lets the wrench round off the hex. When it gets bad enough vise grips are all that works. He could pull the neck and unscrew the main fitting without destroying the temp gauge tube.
But since he's trying to "replace" the gauge cut it and take it off at the water neck. The new gauges come with an assortment of adapters. Put the new one in with teflon tape and tubing wrenches. The next owner will thank you.
ModelA29 is offline   Reply With Quote
