Old 06-30-2025, 04:35 PM   #1
1953M100
1953M100's Avatar
Default Roof "ballooning" while open trailering (!!)
Open trailered my '31 Coupe to a car show in Iowa a couple weeks ago. Headed down 35W interstate at 70mph until I noticed the soft top roof starting to "bulge" and "balloon" at anything above 60mph. Tried to keep my speed down to 55mph the rest of the way, but I don't like travelling 15mph below the speed limit on the freeway, forcing everyone to pass. Not safe. For the trip home I borrowed a few ratchet straps and some carboard to prevent the condition on the return trip, worked pretty well, but kind of a hassle to secure without causing damage. A fella at the car show mentioned there was a cover available for open trailer towing. Tried searching, not finding anything like he described (??). Any of y'all heard of this...?
2024 Bronco Sport, 2016 Roush Mustang, '53 Mercury M100 pickup, '86 Mustang SVO, '31 Model A Coupe
"If there's no plan, what could possibly go wrong...??"
1953M100 is offline   Reply With Quote
Old 06-30-2025, 05:02 PM   #2
Cape Codder
Cape Codder's Avatar
Default Re: Roof "ballooning" while open trailering (!!)
Would backing the car on help?
I don't care if the "A" Starts BUT sure WANT IT TO STOP!
Cape Codder is offline   Reply With Quote
Old 06-30-2025, 05:34 PM   #3
nkaminar
nkaminar's Avatar
Good example of the Bernoulli effect where the pressure is reduced by fluid flow. Same thing happens in the venturi in the carburetor to suck gasoline into the air. Anything you do to reduce the air flow across the roof, like slowing down or some kind of deflector, will help.
Old 06-30-2025, 06:04 PM   #4
Keith True
Keith True's Avatar
Yes,you've found the drawback to hauling a soft top car on an open trailer.My friend has a Dodge dually,when he has the cap on the roof fluctuates almost violently.With no cap on the truck it just flaps up and down a little.Air doesn't jump a very big gap,only about 30 inches,but it mixes back together with a lot of turbulance.Sometimes the turbulance is before the towed vehicle,sometimes right around it.I have a 96 Dodge 2500,single cab,flatbed,and a low profile trailer that I built.I hardly notice a ripple in an A roof at 70.But,if I put the side racks on the flatbed,I can feel the wind buffet the car and trailer around.
Keith True is online now   Reply With Quote
Old 06-30-2025, 06:39 PM   #5
1953M100
1953M100's Avatar
Originally Posted by nkaminar View Post
Good example of the Bernoulli effect where the pressure is reduced by fluid flow...
Exactly! And the more the roof bulges, the faster the air flow, the faster the air flow, the lower the pressure. The lower the pressure, the more the roof bulges.
Lather, rinse, repeat.
Hoping I can find some kind of workable cover for safely open trailering on the interstate.
Lots of car shows and activities I want to attend beyond reasonable driving range for the Coupe.
Old 06-30-2025, 06:39 PM   #6
updraught
updraught's Avatar
Chop about 4 inches out of the roof like the hot rodders do.
updraught is offline   Reply With Quote
Old 07-01-2025, 08:36 AM   #7
Planojc
Planojc's Avatar
I would not tow a car with a car cover. There has been lots of discussion here on that topic.
Planojc is offline   Reply With Quote
Old 07-01-2025, 09:13 AM   #8
David in San Antonio
David in San Antonio's Avatar
As Cape Codder mentioned, towing the car backwards may have merit. Buckminster Fuller (and later, Chrysler / DeSoto) claimed that sedans were more aerodynamically efficient in reverse. Does anyone have experience doing this?
Late ‘30 Deluxe "Wretched Roadster"
1931 Slant Windshield Fordor “Earl Gray”
Alamo A’s Club
David in San Antonio is offline   Reply With Quote
Old 07-01-2025, 09:21 AM   #9
kbinde2
kbinde2's Avatar
When I first purchased my Special coupe I trailered it from Michigan to Delaware, on a U-Haul car trailer. I backed the car on, and made the trip with no adverse effects, except for a wheel strap working loose., the rachet strap had been cut and was just long enough to secure the webbing on the 21" tire.
If I had to trailer again, it would probably be enclosed..
kbinde2 is offline   Reply With Quote
Old 07-01-2025, 09:39 AM   #10
Bob Bidonde
Bob Bidonde's Avatar
nKaminar has it right. More simply stated, the Bernoulli Effect is that an air flow over a surface produces a surface boundary effect that is a suction air load which increases with speed. The suction tends to pull the vinyl top upward.
Bob Bidonde
Old 07-01-2025, 10:08 AM   #11
Will N
Will N's Avatar
The problem with that is that you want the center of mass of the car ahead of the trailer axles. You want a couple hundred pounds of tongue weight on the trailer hitch. If you put the center of mass behind the trailer axles you will have lift on the hitch, which will lead to a very unstable trailer that will fishtail uncontrollably at speed.
Will N is offline   Reply With Quote
Old 07-01-2025, 11:06 AM   #12
ModelA29
ModelA29's Avatar
Or weld a solid roof section from a station wagon like the hot rodders in the 60s did. 57 Ford ones were popular.
ModelA29 is online now   Reply With Quote
Old 07-01-2025, 12:47 PM   #13
BlueSunoco
I'd save up for a good enclosed trailer... problem solved plus protection from the weather
BlueSunoco is offline   Reply With Quote
Old 07-01-2025, 01:59 PM   #14
Dave in MN
Dave in MN's Avatar
I had the same problem with a new roof. I had not stretched the top material enough during installation.
I replaced the top and pulled harder….No more problems.
Good luck!
Dave in MN is offline   Reply With Quote
Old 07-02-2025, 02:26 PM   #15
Tinbasher
Tinbasher's Avatar
I would check the sealant around the edge of the roof material. especially across the front.
a little black sealant around the edge of the mouldings might fix it.
Also try leaving a side or rear window open if you have a roll down rear window. It's all about air pressure.
JP
Tinbasher is offline   Reply With Quote
Old 07-06-2025, 08:54 AM   #16
1953M100
1953M100's Avatar
It's not really a saving problem, more of a storage space issue. Garage is already maxed out, and doors are only 7', an enclosed wouldn't fit. I'm in a residential neighborhood lot, so no outbuildings, no room to store a trailer. I was towing with an open U-haul trailer. Haven't looked into availability of renting an enclosed... (??)
Old 07-06-2025, 09:54 AM   #17
nkaminar
nkaminar's Avatar
I sympathize with your problem. Although the neighborhood where I live would permit our travel trailer to be parked at our house, there is no room. I have to rent a space at a storage lot. It is expensive. I envy my friends who have 40 acres and large storage buildings. But along with the space comes the collection of junk and who is going to get rid that when I am gone?
Old 07-06-2025, 11:35 AM   #18
Phil Brown
Phil Brown's Avatar
Well.......you could always drive it to the show
Phil Brown is offline   Reply With Quote
Old 07-06-2025, 01:33 PM   #19
trulyvintage
trulyvintage's Avatar
Thumbs up Drive Itbl
^^^^^^^^ Here Is Your Answer ^^^^^^^^
Go to shows within driving distance of where
the car is stored, if you must attend a show
at a further distance try going with a group
that will travel together so if something
happens you are in good company to
deal with it.
Jim
trulyvintage is offline   Reply With Quote
Old 07-06-2025, 01:57 PM   #20
1928Mik
1928Mik's Avatar
I was always told never to open-trailer a Model A any faster than the car could go, so I stay at 55 or so, never using the interstate. Of course mine's a Phaeton too. If I had a distance to go, then I'd buy an enclosed trailer, not use a cover..
1928 Niagara Blue Phaeton
1972 Olds 442 Convertible 455 5 speed Restomod
1976 MGB
-Life's Too Short To Drive Boring Cars-
1928Mik is offline   Reply With Quote
