Open trailered my '31 Coupe to a car show in Iowa a couple weeks ago. Headed down 35W interstate at 70mph until I noticed the soft top roof starting to "bulge" and "balloon" at anything above 60mph. Tried to keep my speed down to 55mph the rest of the way, but I don't like travelling 15mph below the speed limit on the freeway, forcing everyone to pass. Not safe. For the trip home I borrowed a few ratchet straps and some carboard to prevent the condition on the return trip, worked pretty well, but kind of a hassle to secure without causing damage. A fella at the car show mentioned there was a cover available for open trailer towing. Tried searching, not finding anything like he described (??). Any of y'all heard of this...?
2024 Bronco Sport, 2016 Roush Mustang, '53 Mercury M100 pickup, '86 Mustang SVO, '31 Model A Coupe "If there's no plan, what could possibly go wrong...??" |
Would backing the car on help?
I don't care if the "A" Starts BUT sure WANT IT TO STOP! |
Good example of the Bernoulli effect where the pressure is reduced by fluid flow. Same thing happens in the venturi in the carburetor to suck gasoline into the air. Anything you do to reduce the air flow across the roof, like slowing down or some kind of deflector, will help.
Yes,you've found the drawback to hauling a soft top car on an open trailer.My friend has a Dodge dually,when he has the cap on the roof fluctuates almost violently.With no cap on the truck it just flaps up and down a little.Air doesn't jump a very big gap,only about 30 inches,but it mixes back together with a lot of turbulance.Sometimes the turbulance is before the towed vehicle,sometimes right around it.I have a 96 Dodge 2500,single cab,flatbed,and a low profile trailer that I built.I hardly notice a ripple in an A roof at 70.But,if I put the side racks on the flatbed,I can feel the wind buffet the car and trailer around.
#5 | |
![]() Lather, rinse, repeat. Hoping I can find some kind of workable cover for safely open trailering on the interstate. ![]() Lots of car shows and activities I want to attend beyond reasonable driving range for the Coupe.
I would not tow a car with a car cover. There has been lots of discussion here on that topic.
As Cape Codder mentioned, towing the car backwards may have merit. Buckminster Fuller (and later, Chrysler / DeSoto) claimed that sedans were more aerodynamically efficient in reverse. Does anyone have experience doing this?
David in San Antonio Late ‘30 Deluxe "Wretched Roadster" 1931 Slant Windshield Fordor “Earl Gray” Alamo A’s Club |
When I first purchased my Special coupe I trailered it from Michigan to Delaware, on a U-Haul car trailer. I backed the car on, and made the trip with no adverse effects, except for a wheel strap working loose., the rachet strap had been cut and was just long enough to secure the webbing on the 21" tire.
If I had to trailer again, it would probably be enclosed.. |
nKaminar has it right. More simply stated, the Bernoulli Effect is that an air flow over a surface produces a surface boundary effect that is a suction air load which increases with speed. The suction tends to pull the vinyl top upward.
Bob Bidonde |
#11 | |
The problem with that is that you want the center of mass of the car ahead of the trailer axles. You want a couple hundred pounds of tongue weight on the trailer hitch. If you put the center of mass behind the trailer axles you will have lift on the hitch, which will lead to a very unstable trailer that will fishtail uncontrollably at speed. |
#13 |
I'd save up for a good enclosed trailer... problem solved plus protection from the weather
#14 |
I had the same problem with a new roof. I had not stretched the top material enough during installation.
I replaced the top and pulled harder….No more problems. Good luck! |
#15 |
I would check the sealant around the edge of the roof material. especially across the front.
a little black sealant around the edge of the mouldings might fix it. Also try leaving a side or rear window open if you have a roll down rear window. It's all about air pressure. JP Last edited by Tinbasher; 07-02-2025 at 02:27 PM. Reason: missed a word. |
#16 |
It's not really a saving problem, more of a storage space issue. Garage is already maxed out, and doors are only 7', an enclosed wouldn't fit. I'm in a residential neighborhood lot, so no outbuildings, no room to store a trailer. I was towing with an open U-haul trailer. Haven't looked into availability of renting an enclosed... (??)
#17 |
I sympathize with your problem. Although the neighborhood where I live would permit our travel trailer to be parked at our house, there is no room. I have to rent a space at a storage lot. It is expensive. I envy my friends who have 40 acres and large storage buildings. But along with the space comes the collection of junk and who is going to get rid that when I am gone?
#18 | |
#19 |
^^^^^^^^ Here Is Your Answer ^^^^^^^^
Go to shows within driving distance of where the car is stored, if you must attend a show at a further distance try going with a group that will travel together so if something happens you are in good company to deal with it. Jim |
#20 |
I was always told never to open-trailer a Model A any faster than the car could go, so I stay at 55 or so, never using the interstate. Of course mine's a Phaeton too. If I had a distance to go, then I'd buy an enclosed trailer, not use a cover..
1928 Niagara Blue Phaeton 1972 Olds 442 Convertible 455 5 speed Restomod 1976 MGB -Life's Too Short To Drive Boring Cars- |
