Old 06-25-2025, 03:06 PM   #1
Road Trip
Default '35 Early vs Late clarification
I have a '35 Fordor hump sedan, and I've run across a few things that tells me it's an "Early" '35. My inner fenders are not louvered; the cowl is sans X at the side of the firewall. When did the changes occur, and are some parts more / less desirable / rarer than others due to it's "earliness"?
Thanks in advance.
Road Trip is offline   Reply With Quote
Old 06-25-2025, 03:18 PM   #2
nelsb01
nelsb01's Avatar
Default Re: '35 Early vs Late clarification
You need the EFV-8C's 1935-1936 Ford Book.
https://shop.efv8.org
nelsb01 is offline   Reply With Quote
Old 06-25-2025, 03:28 PM   #3
rockfla
rockfla's Avatar
There "most likely" are a few "other" early details, the intake manifold and the inner louvered grill panel pictured are also tell tail "early" indicators., at The early 35 intake, at first glance looks like a 34 BUT there are a few differences...mainly the fuel pump stand opening is round and not diamond shape. Pictured are the two "main" early late intakes, then a early one by itself. The grill pan doesn't have the raised area around where the crank handle goes trough!!!
rockfla is online now   Reply With Quote
Old 06-25-2025, 03:32 PM   #4
rockfla
rockfla's Avatar
Just for reference here is the mid/late grill pan
Old 06-25-2025, 08:28 PM   #5
mercman from oz
mercman from oz's Avatar
mid/late 1935 Ford grille pan - rockfla
Old 06-25-2025, 08:41 PM   #6
mercman from oz
Early & Late 1935 Ford Intake Manifolds - rockfla
Old 06-25-2025, 09:24 PM   #7
Road Trip
Assuming the engine and trans is no longer present - or has been replaced...... I was referring to the body (and frame, as there are early / late differences.
Old 06-25-2025, 09:47 PM   #8
barnfind
I believe the front door window mechanism would have have 8 mounting bolts on a "Late" 35.
barnfind is offline   Reply With Quote
Old 06-26-2025, 01:07 AM   #9
rich b
rich b's Avatar
The door handle is located well forward on earlier '35s with the window crank (6 bolt regulator) behind it. Sorry the the picture of the '35 door does not have the regulator installed; but the 6 mount holes and hole for the operator shaft should give you the idea.
Later the door handle was moved closer to the center of the door; but the window crank was left in the original location (still 6 bolt regulator)
Not long after that the window crank (8 bolt regulator) was moved forward to better clear the door handle.
Old 06-26-2025, 02:22 AM   #10
deuce lover
deuce lover's Avatar
Gauge face color might vary from early to late. Here is a pic of the early 35 Oil/Fuel gauge. The outer and center circle has darker graphics.From my experience later in the year it was silver/gray which carried over to 1936.
Old 06-26-2025, 05:27 AM   #11
Terry,OH
Terry,OH's Avatar
Frame body mounts are very different on the early 35
Old 06-26-2025, 10:34 AM   #12
petehoovie
petehoovie's Avatar
