Old 06-05-2025, 06:10 PM   #1
drfromnc
Default Windscreen hinge to header screws
Anyone know the proper size screw type, length, thread pitch for the windscreen hinge to header fastener on 32-34 pickup?
drfromnc is offline   Reply With Quote
Old 06-06-2025, 07:02 AM   #2
Mart
Mart's Avatar
Default Re: Windscreen hinge to header screws
If it is the same as my 32 sedan the thread is #12-24. The head is a pan head or binding head. I used 3/4" screws but they are a bit long. 1/2" would do. The screws are slotted.
Edit: I might be giving wrong info. These are for the bracket on the windshield frame to the hinge.
Old 06-07-2025, 06:39 PM   #3
Don Rogers
Don Rogers's Avatar
Here are some notes from my 35 panel delivery
Don Rogers is offline   Reply With Quote
Old 06-07-2025, 07:29 PM   #4
petehoovie
petehoovie's Avatar
Old 06-07-2025, 09:14 PM   #5
Newc
Newc's Avatar
Note 32/34 PU [trucks] use a long 'piano' hinge. Full length rubber seal between hinge and body. Very flat head machine screws about 1/2' long. Nuts go on top of header strip. Take two persons to install usually. One full length hinge. Newc
Newc is online now   Reply With Quote
Old 06-08-2025, 05:43 AM   #6
drfromnc
Yes I have 2 of the frames with hinges. Nuts on my cab are cage nuts welded to body. They do look like a bear to install especially after fitted with glass.
I bought a package of 4 screws from ThirdGen that stated for 32-36 closed car windshield to header but I need 6 more. They appear to measure 12-24. Went to my local how store that has a massive collection and didn’t find any 12-24. McMaster only has SS to match.
Guess I will do a test fit of hinge and frame with screw set before I order 4 more from thirdgen.
Old 06-08-2025, 08:27 AM   #7
KiWinUS
KiWinUS's Avatar
In our area Home Depot has 12/24 stainless steel Lowe’s or Ace do not.
Old 06-08-2025, 02:19 PM   #8
drfromnc
Thanks Tony. Worth a look.
