When I had a freshly rebuilt Holley 94 on my 1951 Ford, the idle was quite smooth. I made one 80 mile trip and the idle was very rough. I've tried adjusting the idle needles and the curb idle, but it still runs rough. I used the old trick of clamping my hand over the carburetor throat to suck out anything that might be in the idle passages; no better. I removed the idle needles and sprayed the idle ports with carburetor cleaner; no better. Off idle, the engine runs fine, but it still won't idle smoothly like it did before my trip.
I replaced the spark plugs, rotor and cap (I have Pertronix ignition, so no points); and still no difference. I did a compression test and all cylinders are 130 plus or minus 10 PSI. Anyone have ideas why my 8BA won't idle smoothly? Thanks |
Lose the "Pertronix"...
Check all your vacuum hoses
Leaking power valve in the carb base or poor mating surface in the power valve chamber where the carb sits on the base causing a vaccum leak. Some of the new valves don't seat properly without a slight modification.
I'm with the vacuum leak folks. I have had more than a few 'rough idle, but good performing' engine issues over the years and that most often involves a vacuum leak. Sometimes in unusual places. Use an aerosol spray or unlit propane torch and see if it smooths out when you hit a certain spot.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
Agree , check vacuum leaks and the wiper switch for hissing ,aka leak
I'm in the vacuum leak camp as well.
Not sure why there is so much hate for the Petronix unit. I'd be willing to bet that those folks who have issues with them, didn't set them up correctly, used the wrong coil or other issues that are not a fault of the Petronix unit. When the directions are followed as written, they work great. |
Most of these replies say vacuum leak, but I strongly agree with Steve51 in saying that it sounds like the classic ruptured power valve.
Sal |
Could be your idle mixture screws.Take both of them out and blow compressed air in screw holes and replace them.Check how many turn before you take them out.Maybe about 1 1/2 to 2 turns out?I have had this problem of rough idle and this solved my problem.
I think you are right. I saw a video that demonstrates how the gasket under the power valve might get hooked on a ledge on the power valve and cause a vacuum leak. I couldn't check for that, but with the engine running, I shot some carburetor cleaner on the gasket for the power valve chamber and on the vacuum connectios on the carburetor and the vacuum chamber; and saw no difference in the idle quality. I guess I'll have to pull the carburetor apart.
#12 | |
Sal Last edited by scicala; 06-02-2025 at 09:24 PM. |
#13 |
As to the ruptured PV diaphragm, if it ever backfired through the carb, it may have "blown" the PV diaphragm.
#14 | |
#15 | |
Later generations of Hollys and Demons had a mini-check valve in that vacuum circuit. I’m surprised some entrepreneur hasn’t made a retrofit for the older carbs. I believe a lot of guys running the old carbs are fighting mismatched power valve seats/gaskets and ESPECIALLY backfires. |
#16 |
There are a few sellers who have the modified power valves. I rebuilt my carb after having this same issue but my kit had the poor fitting power valve. I used a small sharp edge file to square off that rounded area on the valve that causes it not to seat properly. I also just disconnected my non functioning wipers and hooked up a vaccum gauge under the hood. Its temporary till I get around to dealing with the wipers but its a great diagnostic tool.
#17 | |
