Old 05-17-2025, 12:06 PM   #1
91A-77B
Default Petronix in Mallory Distributor
I have a front-mount points-style Mallory on my 59A. Can I use the Petronix conversion?
91A-77B is offline   Reply With Quote
Old 05-17-2025, 12:24 PM   #2
TJ
TJ's Avatar
Default Re: Petronix in Mallory Distributor
Why make the change? If something happens with the Pertronix I doubt you can get a replacement at any auto store if you are on a trip. Much easier to carry a spare distributor if you have a problem.
Old 05-17-2025, 01:00 PM   #3
mfirth
Also, you must use their specific coil for your application or you'll have trouble. I know of more than one person who went back to a points system.
mfirth is offline   Reply With Quote
Old 05-17-2025, 01:33 PM   #4
tubman
tubman's Avatar
6 volt Pertronix units seem to be more trouble-prone than the 12 volt units. Also, the "noisy" power produced by generators can cause problems.
A points system usually will deteriorate over time, giving you a warning in time to "limp" home. Electronics have a nasty habit of failing immediately and completely, increasing the chance of leaving you stranded.
Old 05-17-2025, 05:34 PM   #5
Fritz
Fritz's Avatar
Let me speak from personal experience. I have a 6v positive ground Pertronix in a crab distributor with a generator. It’s been flawless for over 10 years. It is true you need to use the coil Pertronix recommends and install the module exactly as they instruct.
Cars and metal rust away and are destroyed, but the Word of God will stand forever (Isaiah 40:8, Matthew 24:35).
Fritz is offline   Reply With Quote
Old 05-18-2025, 12:14 PM   #6
91A-77B
I learned a lot from your comments, guys. Including how to spell Pertronix. I'm running a B&M blower on a 284 cu in 59A, and thought I'd adapt my points-type Mallory to electronic. Sounds like I'd better stay with what I've got, unless other Barners have additional ideas. Thanks for your input.
Old 05-18-2025, 12:36 PM   #7
91A-77B
Is there a source for points/rotor/cap/springs for my Mallory 3-bolt #2571601?
Old 05-18-2025, 01:37 PM   #8
tubman
tubman's Avatar
I usually deal with the 8BA and other later model Mallory distributors, but have found direct replacement points for some of them made by other manufacturers (Echlin, Standard, etc.). I'll bet they cross to the earlier units as well. Post the Mallory part numbers you need and I'll check and see if any match. I believe the crab caps are still available. I do not know about rotors and springs, but would be willing to bet they are also used in other applications as well; it would have made no sense for Mallory to tool up their own special small parts. I have also been able to get spares on eBay. Just keep watching; it's not so much if the parts are available, it's getting them at a decent price.
Old 05-18-2025, 01:37 PM   #9
Fritz
Fritz's Avatar
Sorry, I’m not familiar with the Mallory units, but if you search on these Fordbarn forums, there was a member named “Bubba” Jim Linder who wrote a lot of these ignitions, including his advice to install Pertronix modules in them. He wasn’t afraid of electronic ignitions.
Old 05-19-2025, 09:27 AM   #10
glennpm
glennpm's Avatar
I have had the Pertronix I and II on my 59AB Mallory crab distributor. The Pertronix I failed outright stranding me. I was unable to verify this with the seller but found a text online. These are attached.
The Pertronix II didn't work the best and after getting stranded with the I, I changed back to points. When I did this I found that the supposed rebuilt unit from the same seller, wasn't. When I took the modified plate with the Pertronix II off, I found oily sand in the body and the damper leather was completely worn out resulting in metal on metal contact. So much for being rebuilt :-( The Pertronix II passed the attached test for my 12V negative ground system.
I'll probably sell this.
File Type: jpg Function_Test_for_Pertronix_Positive_Ground_Module.jpg (42.4 KB, 9 views)
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
