Old 05-08-2025, 02:54 PM   #1
Steves46
Steves46's Avatar
Default Voltage Regulator
Regarding 6 V positive ground system, does the voltage regulator also need to be 6 V positive ground or does it not matter?
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 05-08-2025, 03:46 PM   #2
Ken/Alabama
Ken/Alabama's Avatar
Default Re: Voltage Regulator
Yes
Old 05-08-2025, 04:01 PM   #3
meric42
meric42's Avatar
No, the regulator is not polarised, the generator needs to be polarised to operate on positive ground. The regulator is primarily regulating the current supplied to the battery and cuts out at a particular voltage threshold regardless of polarity. Do a google search on polarising your generator. Hope this helps
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP
Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand
https://www.fordbarn.com/forum/album.php?albumid=580
meric42 is offline   Reply With Quote
Old 05-10-2025, 03:59 PM   #4
Brian
Brian's Avatar
Although the regulator will work either way, depending on how the generator is polarised, negative grounded regulators have the flat contact point on the regulator armature. On positive grounded regulators the flat contact point is in the upper contact bracket. (The other point is rounded or crowned.) Using the wrong polarity regulator will cause the points to pit badly and give very short life. Regulators designed for positive grounded systems have copper plated current and voltage regulator armatures while regulators for negative grounded systems have cadmium plated armature
