Old 05-04-2025, 10:31 AM   #1
flatmotor40
flatmotor40's Avatar
Default led headlight for 40
Need to see better at night.What is the best headlight conversion for the 40 headlight bucket?
flatmotor40 is offline   Reply With Quote
Old 05-04-2025, 01:40 PM   #2
Fritz
Fritz's Avatar
Default Re: led headlight for 40
I found relays and 6v halogen bulbs made for lights as bright as any modern car. Relays save your switches and sealed beam bulbs produce proper beams. I could not find any 6v led headlight kits for 1940 Fords.
There are halogen housings that you could fit a led bulb into, but I do not believe you would get a good beam and would probably blind other drivers.
Cars and metal rust away and are destroyed, but the Word of God will stand forever (Isaiah 40:8, Matthew 24:35).
Fritz is offline   Reply With Quote
Old 05-04-2025, 06:09 PM   #3
Karl Wescott
Karl Wescott's Avatar
The stock 1940 bucket accepts a 7" "industry standard" sealbeam, "6014" 12 volt, "6006" 6 volt. There are a wide variety of direct replacement led bulbs and conversion kits as these lights were used well into the 1970's.
Karl Wescott is online now   Reply With Quote
Old 05-05-2025, 07:01 AM   #4
flatmotor40
Thanks
Old 05-05-2025, 08:55 AM   #5
TJ
TJ's Avatar
Check the ground to each light. Make sure they have a good clean ground. A poor ground may be part of the problem.
Old 05-06-2025, 08:52 AM   #6
flatmotor40
They work but as I get older I don't drive at night but end of month have to do a wedding in the car and it will run into the night.So that is why I would like to get brighter headlights.
