Old 04-25-2025, 02:36 PM   #1
oldford
Default Where are numbers stamped on a 32 36 transmission
The transmission I found has no vin number on it or anywhere else are numbers that I can tell. The owner said he believes it is either a 32 or up to a 36. The car it is in is a 32.
oldford is offline   Reply With Quote
Old 04-25-2025, 02:41 PM   #2
big deuce
big deuce's Avatar
Default Re: Where are numbers stamped on a 32 36 transmission
Sure it's a Ford?
big deuce is online now   Reply With Quote
Old 04-25-2025, 02:46 PM   #3
Kube
Kube's Avatar
It could be a service part. No numbers on those. I have two NOS cases and neither has a number.
Old 04-25-2025, 03:39 PM   #4
cas3
What is the number cast into the back, bottom of the case?
Old 04-25-2025, 06:37 PM   #5
DavidG
DavidG's Avatar
The part number of the case itself.
Old 04-25-2025, 06:48 PM   #6
cas3
I know that, thats what will answer the question as to what year, or shall we say model its from.
Old 04-25-2025, 07:56 PM   #7
PeteVS
PeteVS's Avatar
'32 has a unique top casting to mount the parking brake handle assembly to.
Old 04-25-2025, 10:10 PM   #8
oldford
This transmission has the parking brake handle mounted to the top casting. Don't they all.
Old 04-25-2025, 10:58 PM   #9
cas3
Top covers interchange up to 36, only 32 is unique. Whats the number cast on the back of the case?
Old 04-26-2025, 12:43 AM   #10
Chris Haynes
Chris Haynes's Avatar
The Model B transmission has no number on it. The number will be on the flywheel housing.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 04-26-2025, 08:15 AM   #11
big deuce
big deuce's Avatar
How about posting some pictures... there seems to be not enough clarification about shifter tops, and "numbers". The 32 year only has casting bosses in the shifter top for emergency brake, and yes other years had the emergency brake "mounted" to the shifter tip via a bracket. I regards the the numbers cas3 was asking for, they are at the bottom and would help determine the era of build. 18- or 48- or 78-7006 will be cast into case right below the lower cluster shaft. Is the shifter tower straight up and down, or at an angle?
File Type: jpg Flathead_Trans_1933-35shifterhousing.jpg (22.8 KB, 56 views)
Old 04-26-2025, 10:21 AM   #12
petehoovie
petehoovie's Avatar
