Old 04-14-2025, 03:48 PM   #1
CleaningTheGarage
Default Identification Help Please.
Found this in a box of Model A parts I picked up at an auction. 1/2 of a set to stamp something?
It's 4" wide, 5" tall and 1 5/8 Deep. Weighs just under 7lbs. As best I can tell it is marked;
Ford AB-7353-A
699-7352 79925 CH
Anyone?
Thanks!
CleaningTheGarage is offline   Reply With Quote
Old 04-16-2025, 01:22 PM   #2
ModelA29
ModelA29's Avatar
Default Re: Identification Help Please.
Ford AB-7353-A - is not a typical part/casting number. The 7353 would indicate it's a transmission/clutch part. The AB is typically where Ford puts the date code but that doesn't match their scheme. The A would indicate the first change/update to the part.
https://www.mustangtek.com/FordDecode.html
https://ocpnw.com/decoding-ford-part...OqPisUgUYPPTNK
ModelA29 is offline   Reply With Quote
Old 04-16-2025, 04:16 PM   #3
nkaminar
nkaminar's Avatar
Wild guess: It looks like this may be a tool of some sort.
Old 04-16-2025, 04:44 PM   #4
mercman from oz
mercman from oz's Avatar
Need help to identify this mysterious Part. Any suggestions?
Old 04-16-2025, 06:43 PM   #5
nkaminar
nkaminar's Avatar
Maybe a forging tool to forge some T shaped part. Or a die to mold sheet metal into a T shaped part. The patterns are too far apart to be used on a single sheet of material as there would be too much waste. I will vote for a forging die. What part on a Model A has this shape?
Old 04-17-2025, 07:58 AM   #6
1942deluxe
1942deluxe's Avatar
I think it is a Ford dealership special tool for working on a Fordomatic/ Mercomatic. If you could find a Manzel tool catalog, it may show up there. Best guess is that is in the 1952-54 era. Nothing to do with a Model A.
Old 04-17-2025, 09:45 AM   #7
katy
katy's Avatar
What material is it? Steel? Cast iron?
Old 04-17-2025, 03:06 PM   #8
CleaningTheGarage
Cast Iron.
Old 04-18-2025, 12:39 AM   #9
mass A man
mass A man's Avatar
I believe it is the Ford conference room cigar holder, holds up to 8 stogies.
mass A man is offline   Reply With Quote
