Old 04-04-2025, 01:25 PM   #1
Bustingear
Default Ford Flathead transmission Gear Ratios
I know it is a Ford open drive post 1939 with the desireable large double detent shift tower but I am trying to find out the 1st, 2nd ,and 3rd gear ratios. Anyone close to these?
Number on the base rear case 78-7006
Number on Shift Tower 81A-7222B
Serial number on upper bell area 799C-I 906942
Thanks
Bustingear is offline   Reply With Quote
Old 04-04-2025, 01:34 PM   #2
Ken/Alabama
Ken/Alabama's Avatar
Default Re: Ford Flathead transmission Gear Ratios
Depends on tooth count on the cluster gear. Third gear is 1:1 regardless.
Old 04-04-2025, 02:10 PM   #3
Bustingear
i have it open, which gear and how do i go about counting? Is the cluster one of the bottom gears in the case or is it sevral i have to count?
Old 04-04-2025, 02:34 PM   #4
deuce lover
deuce lover's Avatar
Yes the bottom. The large end which is at the front of the case should be 28 or 29 tooth.
Old 04-04-2025, 02:40 PM   #5
tubman
tubman's Avatar
After 85 years, there's a chance it might be 25 or 26 as well.
Old 04-04-2025, 03:01 PM   #6
Bustingear
any tricks to counting that without taking it apart? Can only see the edge and too greasy to mark?
Old 04-04-2025, 03:26 PM   #7
Ken/Alabama
You can count the teeth on the top gear that’s on the input. Most of the time , if it has 16 teeth the cluster will have 28 teeth. If it has 15 the cluster will have 29. Usually between the two they will add up to 44. But I have seen this not always applies.
Old 04-04-2025, 03:33 PM   #8
cadillac512
cadillac512's Avatar
The input shaft will have either 16 or 15 teeth if the cluster has 28 or 29. The pairs will add up to 44. (16+28 or 15+29) Those are common. VanPelt's website lists the ratios of the various combinations over the years.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 04-05-2025, 07:43 AM   #9
Mac VP
Mac VP's Avatar
Here’s the link to our gear ratio chart:
http://www.vanpeltsales.com/FH_web/f...gearratios.htm
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 04-05-2025, 11:12 AM   #10
Tim Ayers
I use a grease paint pen to mark a tooth on the large cluster. You’ll see it as it comes around and use a thin straight screwdriver to help you count the teeth
Old 04-07-2025, 06:18 AM   #11
Bustingear
According to Macs chart and the fact that it has a 15 tooth main gear there is no need to count the cluster ...It will have a 3.14 1st gear. Got it. Thanks Mac ! Going to call you for some gaskets and seals when you return from vacation.
Old 04-07-2025, 07:12 AM   #12
Tim Ayers
Like Tubman says, after 85 years, nothing is for certain in these transmissions and take nothing for granted. I would confirm everything is right while you have it apart.
