Old 04-01-2025, 10:50 AM   #1
David in San Antonio
David in San Antonio's Avatar
Default Where to get extended ground strap?
Working through intermittent lights / horn. Where can I get an extended ground strap to connect battery to the frame and to a transmission bolt? Discussions here suggest it might be one piece or an additional one for the frame to the transmission. I’ve searched the suppliers but maybe I’m using the wrong term.
Late ‘30 Deluxe "Wretched Roadster"
Alamo A’s Club
David in San Antonio is offline   Reply With Quote
Old 04-01-2025, 11:41 AM   #2
Hitman
Default Re: Where to get extended ground strap?
Make one, it just has to be a wire that connects two points. You're only enhancing an existing ground, giving a better/cleaner path. A wire, with two bolt eyelet connectors on each end. Mine goes frame to a transmission bolt. In other old cars I go frame to starter bolt.
People will likely chime in it has to be so big to carry so much current, but its only a ground. Go look at the ground wire on your house, it's not that big.
Hitman is online now   Reply With Quote
Old 04-01-2025, 11:49 AM   #3
Jim Brierley
Hitman is right, and your new ground won't be handling starter amperage, only smaller amps, so a #10 or 12 would work.
Old 04-01-2025, 03:19 PM   #4
jak
i've always used the braided cable to go from the battery to the frame. Then under the same bolt I use a disconnect switch cable and go from the frame to one of the transmission tower bolts.
https://www.brattons.com/ELECTRICAL-...uctinfo/20180/
it has always worked well for me.
jak is offline   Reply With Quote
Old 04-01-2025, 03:31 PM   #5
Y-Blockhead
Y-Blockhead's Avatar
Do you use a disconnect switch? It should be between the battery and ground.
Old 04-01-2025, 03:44 PM   #6
Mike1291
Mike1291's Avatar
I wouldn't be so quick to say that. One of the reasons to add an extra ground to the transmission is to provide a better ground path for the starter. My starter spins about twice as fast now with an extra ground. I'd recommend the cable that jak recommended.
Feb '31 Standard Coupe
Member of the Little Rhody Model A Club & MARC
Mike1291 is offline   Reply With Quote
Old 04-01-2025, 04:04 PM   #7
Ayers1
Ayers1's Avatar
I measured from the bolt of the ground strap to whatever point I decided to go (I believe it was transmission housing) and went to a local auto parts store. I asked for a starter cable with a loop on each end in the length I wanted. A 12 volt starter cable is definitely plenty heavy for an extra ground cable.
Steve,
Proud owner of
28 Fordor, been in family since 63
30 Tudor
31 S/W Town Sedan
Skyline Chapter MAFCA, MARC
Ayers1 is online now   Reply With Quote
Old 04-01-2025, 04:35 PM   #8
Thanks for the suggestions!
At the same time I’m going to add a disconnect switch. Starting another thread.
Alamo A’s Club
Old 04-01-2025, 04:55 PM   #9
JayJay
If you do a web search for "custom battery cables" you will find several suppliers. And it used to be that a good auto parts store would make up one for you to your specs, not so much now in the age of "uh, what kinda car is dat for?" parts counter workers.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 04-01-2025, 06:29 PM   #10
BButturff
BButturff's Avatar
I purchased the Deka p/n 01051 braided 4-hole ground strap from Blain's Farm and Fleet. If you don't have a Blain's near you they will ship it. You can check it out here:
https://www.farmandfleet.com/product...W_7BAzhk&gQT=1
BButturff is offline   Reply With Quote
Old 04-01-2025, 08:43 PM   #11
shiver
I fabbed my own ground cable
shiver is offline   Reply With Quote
Old 04-02-2025, 01:57 AM   #12
German guy
German guy's Avatar
I'm with Hitman on this one. My presumptuous mechanic added a 10 gauge ground wire from the battery to the transmission in addition to the existing braided one to the frame. I did not notice the new wire when I collected the car at the garage but immediately noticed an improvement in starter speed and quick start. I only noticed the additional wire once I got home. The A loves lots of ground.
German guy is offline   Reply With Quote
Old 04-02-2025, 06:35 AM   #13
shiver
When the splash pans are removed the ground path is through the driveline clamshell and front motor mount, both of which are sketchy for continuity. I run the large strap in case due to starter amperage potentially using the strap as a path. A clear paths for continuity ( the “loop” from positive to negative is critical for component life as well.
Old 04-02-2025, 06:57 AM   #14
jak
no i just use that cable because it is a good heavy wire with an eye at each end for the bolt to attach.
Old 04-02-2025, 07:33 AM   #15
nkaminar
nkaminar's Avatar
I am with Jak and the others who recommend a heavy ground strap. Has to carry starter current.
Old 04-02-2025, 09:01 AM   #16
rfitzpatrick
Is it fact? I need an extra engine ground with Float-A-Motor engine mounts?
TKS
rfitzpatrick is offline   Reply With Quote
Old 04-02-2025, 09:31 AM   #17
Keith True
Keith True's Avatar
Stock mounts have no more ground path than floaters.There is NO metal to metal contact between the frame and mount with either one.Now if the stock mounts are sagging,or the rubbers have worn through,you might get some contact,but it's not supposed to be there.
Old 04-02-2025, 09:46 AM   #18
katy
katy's Avatar
TKS
Might not be needed, but can't hurt anything by having one.
Old 04-02-2025, 09:48 AM   #19
Y-Blockhead
Not what I asked. Do you have a disconnected between the Battery and Ground? You said you use a braided cable to ground.
Old 04-02-2025, 10:37 AM   #20
Davew
Davew's Avatar
I went to the local NAPA store and they made me one.. any size I wanted
Davew is offline   Reply With Quote
