I saw a beautiful show truck, 41 1/2 ton, appeared to have the rings that go on the 16" wheels that were chrome, and the wheel was painted to match the truck. Looked great, wondering if anyone has done that, and if you can put the ring on without damaging the chrome? TIA!
Shouldn't be an issue damaging the chrome.There are relief cut outs to slip the ring on the wheel after tire and tube are installed and then the tire is slowly inflated.While inflating make sure that the groove on the ring is locked in place on the rim.When I worked in a tire shop in the early 1960's we inflated these in a cage or upside down.
if you chrome them they will need to be heat treated buy someone that knows what their doing. If you dont you risk them failing from chemical embrittlement [trust me i know]
Can you share a picture? I'm not familiar with a 1940 1/2 ton commercial chassis with lock ring 16" wheels. I have seen lock rings on the 1 1/2 ton trucks, but not the smaller 1/2 ton trucks.
aussie merc is 100% correct about finding a shop that can both chrome and relief bake immediately after chroming. There is a time limit between the chemical bath and the oven that you don't want to get wrong. |
I think it could be the trim rings that most commonly were on passenger cars that he saw.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
Firestone made them (16" 5X 5.5) and they were adjustable spokes.They also used the 32-35 Ford hubcap.Also there was an artillery wheel ,Clark?,(16")that had the snap ring.5X 5.5 bolt pattern.Here is a pic.
They are not General Jumbo's although the hubcap is similar. The 33 sedan pictures had 2 different pairs of 16" artillery wheels when I bought the car. 1 pair were Budd's .They did not have the snap ring. Last edited by deuce lover; 03-30-2025 at 11:22 PM. |
#8 | |
![]() Quote:
Here are some split ring wheels my dad had on a 1949 F1. They are 15x5.5 the parts book shows then in 1953 TAAA-1007-B. They are stamped FOMOCO.
I found no Budd listing for the 16” locking side ring wheels having 5 x 5.5” pattern. A deeper search might show they were of another manufacturer.
Your TAAA 1007B (K37717) wheels are 1954 replacements for TAAA 1007A (K36877) that was only cataloged in 1953. There was a minor offset change 1953 to 1954. Prior to this the TAAA 1007A went through some number changes dating back to 1947 where it was the mystery wheel 7RC 1015. It seems no one has ever found any of these earliest wheels but clearly they exist(ed). And significant to me, they are cataloged in MH references using the same engineering drawings as Ford’s under MH number LD7 5370. Stu Edit - it might be interesting for you to measure the backspace on your 15” locking side ring wheels. My TAAA 1007Bs measure 3.75” from a straight edge across the rear lips to the center. A TAAA 1007A had 3/8” more offset so your backspace could be that much greater. Stu
Stu McMillan Marmon-Herringtons Last edited by truckdog62563; 03-30-2025 at 06:14 PM. |
I have a set of the Adj early ones ,Firestone,the ring was chromed
cancel
#13 |
Stu, I measured from the arrow to where the wheel contacts the drum and it was 3 5/8".
