I have a chrome Trico vacuum windshield wiper in my 31 Victoria. Is there general maintenance that a person should do with these vacuum wipers? In other words, lubrication, cleaning, all that sort of thing.
I have seen a page showing how to lube a wiper motor. It shows sucking lube by moving the arm with the vacuum hose in some light oil. Best way to keep your motor happy is use it at least a few swipes whenever you're driving the car.
If the vacuum motors sit for a long while they can become gummed up and corroded. The only solution is to take them apart and rebuild them with new gaskets. If they are still working, spray a light oil or 3-in-one oil where the air goes into the motor and do that while they are operating. Do not use WD-40 as it will evaporate over time.
Maybe I am dense, but how do you spray a light oil into the unit when it is operating?
I forget where the air inlet is. Here is a good article on how to lubricate the motor using a hose: http://modelabasics.com/wiper.htm.
Paul Shinn may have made a video about the motor. Any excess oil remaining in the motor will be sucked out by the vacuum when operating.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 02-10-2025 at 12:17 PM. |
Don't need any fancy modern "up to date" windshield wipers. I'll stick with the hand operated one, works every time, variable speed too.
Variable speed and intermittent as needed!!!
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
The hand wipers were generally only supplied with the light commercial pickups and trucks. Most other cars came with either electric or vacuum wiper motors depending on year of manufacture.
When the on/off valve is placed in the ON function, the vacuum is introduced to the shuttle valve chamber. Two of the ports are already open to allow vacuum to draw the paddle off the park chamber and start the oscillating function. Just before the paddle reaches the opposite side, the shuttle valve rocks over to close off one port and open the opposite port to start the paddle back the other way and so on. When the valve is placed in the OFF position, then the vacuum is stopped to the shuttle chamber and the port is opened to the park chamber which allows the paddle to be drawn back to park position and hopefully seal off on the park seal, that is a part of the paddle, to stop the vacuum draw from the engine. A lot of folks lube the paddle & chamber with vaseline and then use light oil or even brake fluid. The shaft and oscillating components can then be lubed prior to reassembly when they have it all apart. Some folks use ATF or brake fluid as a lubricant if going the service method route. It's up to the owner on what they want to use but I prefer ATF myself. Last edited by rotorwrench; 02-10-2025 at 02:58 PM. |
I was told by the person that I bought mine from to smear a light coat of Vaseline on the bottom bowl surface every few years or when needed.
Regards Bill |
#13 |
My wiper was not working, so I followed the lubrication advice and it is moving now. My question is: Is the wiper suposed to continuously move? I am having to push the rod in to move it one way, and pull to move it back. Is that the way it is designed?
#14 |
There is a pneumatic switch that flips back and forth to change the direction of movement. It may just need a little oil. Look at the exploded drawings of the vacuum motor.
#15 |
Yes, the wiper will continuously move.
#16 |
The shuttle valve controls the wiper's constant reversing motions. When the unit is turned off, it should be drawn to the park position.
#17 |
I use a little smear of NAPA "Sil-Glyde". A silicone grease. Doesn't run, gum or melt.
