I bumped into the driver side wind-wing on my '28 roadster and knocked it off. It is undamaged but I'm looking for suggestions on what to use to bond rubber to glass.
Thanks, Robert |
I can't tell you how many I have seen fall off and break.
I use an inner tube and superglue it to the glass. I trim the rubber with an exacto knife around the brackets. Make sure you adjust the little round screw first so that the brackets fold tight against the glass. Then tighten the others. |
I would try contact cement.
Maybe talk to your local glass shop.
good rubber cement.
Hoo boy I’ve been through this and nothing I’ve tried worked. I caught the driver’s side wind wing just before it fell off, twice. I cracked one by clamping it down too hard. I suspect my hardware is no good. The best suggestion I’ve seen here is the fellow from Australia (sorry can’t recall your name) who had reproductions made at a local plastic shop and drilled bolt holes to anchor them.
In the meantime I found that running without them made it so much easier to get in and out , and made no noticeable difference with wind buffeting. Hard to imagine Henry would have continued to bear the expense of needless parts, but that’s my experience.
David in San Antonio Late ‘30 Deluxe "Wretched Roadster" Alamo A’s Club |
There is a cement that's used on more modern cars that they glue the rear view mirror to the windshield I would try using some of that it should be available in any major auto parts store.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
3M™ Marine Adhesive Sealant 5200
- comes in 3oz black tube. https://www.3m.com/3M/en_US/p/d/b40066983/ |
We tested a wing-wing in a club car and after 2 years, still holding great.
Go to the hardware store and buy a roll of 3M heavy duty fixture tape. It's black like the old rubber you have. Cut them out of your rubber pattern, and you will be good to go. Hope this helps |
#10 | |
![]() Quote:
I am considering the 3M product below. 3M products are usually top quality.
Rusty Nelson 3M Rearview Mirror Adhesive, 08752 |
#13 |
That is designed to hold the little metal tab to the windshield in a modern car. It's basically super glue modifed to withstand the UV hitting it through the windshield.
#14 |
Thanks to all of you but I should have supplied more information. I bought the car around 1989, and these wind wings were on the car when I bought it. A few years later I installed a rear-view mirror on the driver side wind wing. Yesterday I bumped that wind wing hard while climbing out of the car and it fell undamaged on my concrete carport floor. Two of the rubber pads are still stuck firmly to the glass. The two that came loose look like they never had any adhesive on them.
#15 |
I wouldn't. Go with the tape and it will be instant and strong. Adhesives
in this situation are not trustworthy. Barge rubber cement- used in the shoe industry. never had a problem. if you buy crap, well yes it could be a problem. |
#16 | |
![]() Quote:
pads? The 3M adhesive tape I recommend is almost the same dimensions as the old rubber.
1928 Roadster Pickup 1930 Tudor 1943 Ford WWII Jeep 1968 Taco Minibike Member, Santa Anita Model A's Arcadia Ca. |
#17 |
The MFG number of the 3M tape is: 414H
3M extreme 30 lb mounting tape.
#18 |
Yesterday I looked at the wind wing clamps again. The rubber pads feel stuck well into the clamps. The surface of clamp pads appear like they never had any adhesive on them. I plan to smear some 3M High Bond Mirror Adhesive on the pads and tighten them as hard as I can. I keep my old Fords in my barn 95 miles from my home and won't be back there for a week or so.
Thanks again for all of your helpful suggestions. Robert |
#19 |
I finally got back to the Model A. I keep it in a barn in a rural area 95 miles from my home. I found my large screwdriver with a square shank in my barn. I tightened the two outer screws as hard as I could with a 3/8" open end wrench on the shank. I think this is going to work but if it doesn't, I'll let you know. Thanks again for your help and patience.
Robert |
#20 |
I ditched the glass wind wings years ago after they kept coming loose. I replaced the glass with acrylic sheet or polycarbonate material. Just to make 110% sure they wouldn't come loose again, I intended to drill through one clamp and the clear sheet, tap the other clamp and put in a screw. The clamp was too hard to easily tap so I drilled right through and used a small nut and bolt. Not even the slightest suggestion of any thing coming loose again. The ONLY down side is the acrylic or poly carbonate is softer than glass and scratches more easily so care must be taken when cleaning it.
I sometimes wonder what happened to the people who asked me for directions. Even at my age, I still like to look at a young, attractive woman but I can't really remember why. |
