Old 03-06-2025, 04:45 PM   #1
1930artdeco
1930artdeco's Avatar
Default how to achieve a rake
OK, I may want to consider this. I was thinking after reading another post somewhere about raising the rear of the car so that it is easier to change tires. I was thinking that is not a bad idea. So...how would I go about raising the rear of my 57 wagon just about 2" or so? I am not trying to get a huge rake, just enough so that it is easier to change tires on her.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 03-06-2025, 04:55 PM   #2
Ford Freak
Default Re: how to achieve a rake
Find a good spring shop in your area. Tell them how much higher you want your car. They will remove the spring's, re-arch them & re-install them. That's the right way to do it.
1952 Ford F1
!956 Fairlane Club Sedan
1965 Falcon Sprint
2007 Mustang GT
Ford Freak is online now   Reply With Quote
Old 03-06-2025, 08:18 PM   #3
miker98038
miker98038's Avatar
People knock them, but my friends Nomad came with a set of air lift shocks. I don’t know how old they are or the miles they’ve got, but they still work fine and he’s had it 20 years. Picks the back up a couple inches. Don’t know if that would help with changing the tires, his car doesn’t have that issue. But they’re slick with the wagon. They only time he uses them is for a load in the back (which is mainly coolers and chairs for shows, sometimes luggage). Other that that, no maintenance or air loss.
Are the shocks the tire change problem? If you disconnect them, does it drop far enough to get them out?
miker98038 is offline   Reply With Quote
Old 03-06-2025, 08:43 PM   #4
paul2748
paul2748's Avatar
Can you reverse the rear spring shackle? That it how it was done in the old days.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 03-06-2025, 09:49 PM   #5
Lanny
Lanny's Avatar
Yup, Pauls idea of flipping both rear spring shackles would usually
raise the rear of the car a couple inches.
We would get a solid iron bar about 4 or 5 ft long and stick it in
the rear shackle and a couple of us would pull or push on the bar
till the shackle flipped, then the back end of the spring sat below
the shackle, thus raising the rear of car higher...
I forgot to say, do this on a hoist.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 03-07-2025, 12:02 AM   #6
Ford Freak
Paul & Lanny - yes, I remember doing that on my first car, a '56 Country Sedan 4 dr. wagon. I forgot about that trick. And, we did do it on a lift! I think perhaps I might just do that on the '56 Club Sedan that I'm working on now. Thanks guys! - FF
1952 Ford F1
1965 Falcon Sprint
2007 Mustang GT
Old 03-07-2025, 01:27 AM   #7
Abe Lugo
Mike you can flip the shackles and have the rake but you really need to put in the longer shocks so the angle drops more when it's jacked up. Also more on my wagon I used the 800-14 radial equivalent radial and the tire comes out easily. I believe my wagon is stock in the rear.
Abe Lugo is offline   Reply With Quote
Old 03-07-2025, 08:51 AM   #8
KULTULZ
KULTULZ's Avatar
Reversing the shackles puts more stress on the main leaf and the spring will droop, especially if they are worn and weak.
The easiest/cheapest way out is with air shocks (IMO). If the springs are shot, it may save them for a while. They are adjustable (vary air pressure) for height and ride.
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 03-07-2025, 11:14 AM   #9
1930artdeco
Thanks for the replies. I am just looking for a slight rake-partly for looks and partly to facilitate tire changes. I have brand new springs and the longer shocks. Maybe I will just use the air shocks, do they hamper ride quality at all?
Thanks,
Mike
1957 Country Sedan
Old 03-07-2025, 01:30 PM   #10
KULTULZ
KULTULZ's Avatar
Arrow Re: how to achieve a rake
GO HERE - https://gabriel.com/HiJackers
Watch the video and read FAQ.
Old 03-07-2025, 02:33 PM   #11
miker98038
miker98038's Avatar
I’ve driven and ridden in that Nomad both loaded and unloaded. But always level. So I don’t know if l lifting it empty would have an effect. I’d guess it would be minor on a small lift.
It’s a nice, tight, rebuilt, maintained car, 350/700R4, front disc. Everything tight and aligned. But it’s a wagon, not a sports car for sure.
Old 03-08-2025, 12:10 AM   #12
Abe Lugo
Another way is just add the brand new station wagon leaf springs in the rear it will be high.
Old 03-08-2025, 09:18 AM   #13
Jeff Norwell
Jeff Norwell's Avatar
Rear springs and I use the the good old rubber rake... different sizes of tires to achieve the nose down look I want
Jeff Norwell is online now   Reply With Quote
Old 03-08-2025, 09:44 PM   #14
55blacktie
I don't like seeing the shackles hanging down when they've been inverted. If you hit a pot hole, etc., the shackle(s) could revert to their correct position, thereby upsetting the handling, possibly at the worst time. I'm not a fan of air shocks either because shocks have the job of controlling rebound; springs are designed to carry the load. However, I would choose air shocks over inverting the shackles. I put new leaf springs on my 55 Tbird; they were purchased from General Spring KC in Kansas. After installing them, along with 15 x 7 wheels/w 215 70R15 tires, I decided I needed more clearance. I removed the new springs, took them to Dentoni's (Stockton, CA) and had the new springs re-arched to provide an additional 1 1/2 inches of clearance. Had I known, I could have asked General Spring to build in the additional 1 1/2 inches.
55blacktie is offline   Reply With Quote
Old 03-09-2025, 01:32 AM   #15
Abe Lugo
Mike.
I had the tires rotated today because I noticed an uneven wear on my front right.
So my new spare goes on there and the rest got moved around. There was no issue with just jacking up the rear.
I'm running radials on that one Coker WW 215/75r14 all around.it supposed to be the 800-14 equivalent.
Here is a pic
Old 03-09-2025, 10:39 AM   #16
KULTULZ
KULTULZ's Avatar
Cool Re: how to achieve a rake
This brings back memories as this look was popular in the day before they figured you need to have large diameter front tires to come off the lights ...
During my first tech years, starting as a REFUELING TECHNICIAN and GAS STATION CASANOVA, a fellow worker was dropped off by his brother. It was at the top of the lot and I couldn't get close to look it over.
He was driving a 49 FORD rag-top, all black, including the top. It had 15" CRAGARS on the rear and 13" CRAGARS on the front with black-wall tires. It was raised the same trim level all around.
It was almost a sexual moment. I never saw it again.
Old 03-11-2025, 02:03 PM   #17
1930artdeco
Abe that is what I am looking for. Just a smidge taller in the rear.
Mike
1957 Country Sedan
