I have a 1940 express truck that was my grandfather's farm truck. It has a 1 ton rear axle(17" split rims) and a 3/4 ton front axle (16" solid rims). I have removed the axles for sandblasting the frame. Now that the frame is primed and installed on the frame table, I noticed the front of the frame is slightly bent. I have been searching for any dimensional information to straighten it back out. I can find the 1/2 ton frame dimensions, but not the 3/4-1 ton. Any help is appreciated. My backup plan is to take a bunch of reference points and triangulate to the opposite side.
Stu or GB should be able to help.
I dig coal, which provides motivation for EVs. |
I have a bare rolling frame from a '46 tonner amd a couple of complete 47 tonners here. I also have the back half of a '39 tonner that was made into a trailer for a welder. I know the axles changed width with an increase in '42 of 2 1/2". Would be easy to determine in the morning. My guess is frame rails will be the standard 34" width. I think my old '38 tonner had a transverse front leaf and I've never owned a '40 or '41. Do they have transverse front or paralell springs?? If paralell, frames may be the same and I can help you..As soon as you can get a picture of this truck posted, we'd love to see it.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
It has parallel springs. The frame is 34" outside in the rear, and 32"outside in the front. I will post some pics ASAP. I have some before teardown and in process. I "heard" it is close to the '46 frames...
#7 | |
![]() Quote:
Yessir, that's a farm truck! Do you have the box, running boards and rear fenders or are you going with a flatbed on your build?
We are keeping the flatbed. The story is that my grandfather had the bed made and installed by a local machine shop so he could haul seed corn in bags. We still have the "original" wooden rack(front "headache" rack) that we will use as a template to remake the sides and rear. I have some rough sawn cedar that most likely will get used for that. I will drawup some dimensions that I am looking for. The right front front spring perch was braized to the frame. It appears the the left front frame rail is bent in and down approx 1/4" inch. Probably not a big concern but I wanted to get the frame straight before getting into the suspension.
I have a 39 and it’s 32” at the front
I am building a 1939 1 ton express |
I have the Salesman’s Data Book for 1941, but not 1940. It has charts with dimensions. I would assume they are the same as 1940, please say if it is not, but the problem I have here is posting pictures from my phone. If GB or Owen are willing to post the pics I will email them. Stu
Stu McMillan Marmon-Herringtons |
I would like to think the 1940 and 1941 are close if not the same. I would appreciate any help. I can "trig" it out myself but it would be better to at least have some sort of starting point.
#13 |
Here are some progress pictures of the frame.
[ATTACH][ATTACH]image000004.jpg[/ATTACH][/ATTACH] |
#14 | |
![]() Quote:
#15 | |
![]() Quote:
Problem is I just got home from a jobsite tonight and I leave at 5:30 am to go to Seattle to see the grandkids. Sorry, bad timing.
#16 |
is that a Ferrari ?
#17 |
Thanks Karl. Email with three charts sent. And thanks Owen for trying to train me. I got to the point of attaching files and I lost it. Will continue to try to learn. Stu
#18 |
Copies of information from Truckdog62563...
#19 |
These are the measurements from the 1940 salesman's Reference Manual.
#20 |
I have a 31 3/4 ton Frame currently at powder coating. If you let me know what dimensions you need, I'll measure it next week when its back in the garage
