Old 02-27-2025, 04:30 PM   #1
50Trucking
50Trucking's Avatar
Default Loose key in rear axle
Is there any way to repair a worn keyway in the rear axle of a model A? I have a new key but it is loose in the axle keyway.
50Trucking is offline   Reply With Quote
Old 02-27-2025, 05:27 PM   #2
nkaminar
nkaminar's Avatar
Default Re: Loose key in rear axle
You could try using a center punch at the sides of the keyway to move metal into the slot. Do this with the key in the keyway. This would be a stop gap repair where the real repair is to replace the axle.
People have said that the key transmits the torque, but the real thing that transmits the torque is the taper on the hub and axle. The nut must be kept tight. I have heard various torques to tighten the nut to but I use a lot more than most. I would contend that 100 foot-pounds is minimum.
Old 02-28-2025, 01:25 AM   #3
Dave Mellor NJ
My uncle used to say As tight as you can get it and then a quarter turn
Dave Mellor NJ is offline   Reply With Quote
Old 02-28-2025, 07:49 AM   #4
larry harding
i worked on harleys some over the years ahd the torque on the head bolts was....as tight as you can get it plus another half turn
larry harding is offline   Reply With Quote
Old 02-28-2025, 08:31 AM   #5
Joe K
Joe K's Avatar
It is possible to have the axle slot "enlarged" and have a "step key" to take the hub.
A fair amount of precision work in this. Possibly better to just get a new axle half.
In buying a replacement, have a key in your pocket and hopefully you'll have a choice of several. Check for a groove at the oil seal (can be a source of failure) Mostly the gear ends look good, but give it a look.
Joe K
Shudda kept the horse.
Old 02-28-2025, 11:00 AM   #6
katy
katy's Avatar
How is the keyway in the hub?
Old 02-28-2025, 11:15 AM   #7
1930artdeco
1930artdeco's Avatar
Just curious, can the key way be welded up and then recut?
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 02-28-2025, 11:21 AM   #8
Joe K
Joe K's Avatar
Mike
This is possible - but you're probably talking full weld/magnaflux/lathe/milling machine rebuilder.
You essentially end up recutting the taper on the axle. This to restore (and prove out) the axle taper as "collinear." Possibly to result in "shims" to make up the difference?
I have heard of someone who cut the keyway on the opposite side. Were this mine I would make a "filler piece" to fill in the old shaft key way.
In mounting a hub, the hub actually "stretches" a bit. I.e. a "plastic deformation." This wants to have "support" in the old keyway area lest the wheel rotate "off-center" in plastic deformation.
Joe K
Old 02-28-2025, 11:31 AM   #9
nkaminar
nkaminar's Avatar
It sounds like Joe K is talking about used axles. Good idea. You can put an ad in the Barn "The Swap Meet" side.
Old 02-28-2025, 12:24 PM   #10
Joe K
Joe K's Avatar
Well, my choice would be "good used" rather than the available "new" where the punkin gear is press/welded/whatever to the shaft - and prone to come apart.
We're now at the point where the wife asks "What on earth am I to do with ALL those Model A parts in the barn after your passing - I'm going to call a scrap yard."
I'm not at all to the same degree but one is reminded of "Page's Model A Garage" in Haverhill, NH. 3 large barns FILLED with Model As, parts, and support ephemera.
Joe K
Old 02-28-2025, 01:18 PM   #11
nkaminar
nkaminar's Avatar
Some day, darling, all this will be yours.
Old 02-28-2025, 02:56 PM   #12
50Trucking
50Trucking's Avatar
Has anyone tried Loctite 680?
Old 03-01-2025, 09:17 AM   #13
Bob Bidonde
Bob Bidonde's Avatar
All of the repair techniques mentioned so far are not structurally sound. If the key gets loose, it will be unable to transmit torque to the wheel. Moreover, the opposite axle key will become more highly loaded shortening its service life. There is no reliable fix for a distorted key-way in the A's axle other than to machine a new one. The axle key must have a snug fit with total contact in the key-way to efficiently transmit the engine's torque to the wheel. I suggest that you replace the axle or have a new key-way cut into your existing axle. The new key-way should be about 180 degrees away from the bad one.
Bob Bidonde
Old 03-01-2025, 10:18 AM   #14
David in San Antonio
David in San Antonio's Avatar
Bob, your slides are a huge help to “visual learners” like me. Many narrative descriptions baffle me, but I understand pictures. Many thanks!
Late ‘30 Deluxe "Wretched Roadster"
Alamo A’s Club
David in San Antonio is offline   Reply With Quote
Old 03-01-2025, 01:27 PM   #15
Richard Knight
Dave, you might want to refer to a thread started in October 2020 by Bob where tapers were discussed. The keyways and keys wear because the mechanical joint of the engineered locking taper has failed most likely by improper tightening of the axle nut. If you would review that thread you might learn about tapers or Google taper fits. It appears Bob has not come to understand how locking tapers work.
Richard Knight is offline   Reply With Quote
Old 03-01-2025, 01:38 PM   #16
noboD
If you don't want to replace the axle, which would be the best, file the radius out of the bottom. Then measure very carefully and make a stepped key that fits tight in the axle. I had to do this to a brand new million dollar shaft at work that the manufacturer screwed up the keyway. We couldn't send the shaft back as the machine was already torn apart and had to be put back in use. It takes time and patience but can be done.
noboD is offline   Reply With Quote
Old 03-01-2025, 01:38 PM   #17
nkaminar
nkaminar's Avatar
I agree with Richard Knight (Post #15). The taper is there to transmit the torque. It was put there in the very early days of the Model T to replace a straight axle that caused problems. Anyone who has used a lathe and put the tapered tool in the tail stock knows that it transmits torque and is hard to remove without backing off the tail stock to force it out. The key and keyway get damaged when the nut is loose and the key transmits the torque.
Old 03-01-2025, 11:17 PM   #18
katy
katy's Avatar
Ditto
Old 03-02-2025, 02:04 AM   #19
larrys40
This is my wheelhouse after rebuilding in excess of 350 Model A and v8 axles over time….. if you have a bad key way on the axle also inspect the hub . The key must fit snug in the axle and the hub . If it is worn and you will most likely see wear on the sides of the axle key, it is best to replace the axles as opposed to undesirable fixes of piening to make it tighter or other methods of band aids.
Loose hub nuts are usually the culprit source of the cause and over time they get worse.
I use to torque the rear axle Nuts to 150, and backed my torque to sometimes 125. If you have good threads it should take it. Use a good new axle nut and make sure that the nuts fit the threads well ( not loose or rocking in the axle - no load).
It is beat to replace the axles if the keway is not sharp . It is easy to tell.
I hear of folks tightening snug with a crescent wrench and low torques. That is NOT recommended and in the best interest of safety….. and always cotter pin. Yes there are stories of Hub/drums coming off… and they are true. How many backing plates have you seen that are flat bottomed before… yea quite a few. Imagine that happening when you are motoring down the road!! You get my drift here.
Folks usually don’t “restore “ the rear axles due to lack of knowledge, tools, and understanding of them and thinking they are turning so they must be ok. Do you treat your engine and trans ok just because they are turning ?
Always inspect all parts… torque the rear axle Nuts to 125 foot lbs. use the thick undamaged axle washers with a well seated out hub seal.
Those if you who’ve been to one of my rear axle seminars at the Marc nationals have seen my axle stub pass around showing broken axle ends !
Inspect and keep ‘em tight!
Happy “A” motoring !
Larry Shepard
larrys40 is offline   Reply With Quote
Old 03-02-2025, 07:40 AM   #20
50Trucking
50Trucking's Avatar
Larry, Have you had any luck in shimming axles that are rubbing the backing plates or the inner side of the drum against the emergency brake band?
