Old 02-15-2025, 04:45 PM   #1
guy1unico
Default 1934 Pickup cab size
Is there more leg room in a 34 cab than a 32 cab for a 1/2 ton pickup?
guy1unico is offline   Reply With Quote
Old 02-15-2025, 06:19 PM   #2
38 coupe
38 coupe's Avatar
Default Re: 1934 Pickup cab size
I think no.
Old 02-15-2025, 06:52 PM   #3
guy1unico
I heard the firewalls were alittle different.
Old 02-15-2025, 07:55 PM   #4
Cool 33
Cool 33's Avatar
Yes the upper part of firewall protrudes in the engine compartment allowing for a more comfortable situated toe board and slightly more leg room. Steve
Cool 33 is offline   Reply With Quote
Old 02-15-2025, 08:59 PM   #5
guy1unico
Thank you Steve, I was thinking about calling you.
Guy
Old 02-16-2025, 10:04 AM   #6
Krylon32
I built my first 32 pickups using 33 cabs (same firewall as 34) and there was slightly more leg room than my last 3 32's with stock firewalls. Also the 33/34 firewall allowed me room to tuck an AC evaporator up under the dash out of sight.
Krylon32 is offline   Reply With Quote
Old 02-16-2025, 03:42 PM   #7
32phil
34 cabs have an extra reveal in the back panel.
It's very obvious when you compare the back panel on 32 & 33 cabs to 34 cabs.
The extra wide reveal allows the seat back to lay back slightly further for a more comfortable angle.
Early Ford Lock & Key Service
https://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
