I do not know if this is 3 or 4 speed, all I know is the SN matches the frame on this 3/4T 41. To order a rebuild Kit, what transmission do I refer to? Thanks!
Call Mac Van Pelt, Van Pelt Sales. He is "THE" transmission man (Guru really) for parts and or any other transmission questions
1-513-724-9486 |
Looks like a big truck 4 speed
thanks!
Warner Gear T9, what Ford called a spur gear. It has no synchronizers. It is the same as the one in my 52 MH R32-4 (F3).
I dig coal, which provides motivation for EVs. |
Definitely a four speed type…..correct for the 1941 V-8 that it’s attached to. It may have the shifter lever with the little trigger operated reverse lockout release (located just below the shifter knob). The ball bearings, caged roller bearings, paper gaskets, rear oil seal are all available….we try to keep those all in stock. After that, it gets very sketchy on what is available. If your truck was a 1/2 ton pickup I would be suggesting that you change over to the three speed transmission for drive ability and parts availability. Not sure if that is doable with the 1 ton truck. If the gears are still in decent shape, I’d refresh the bearings and use it…..getting used to double clutching on every shift.
VANPELT SALES LLC Cincinnati, Ohio Office: 513-724-9486 www.vanpeltsales.com www.classictransmission.com |
thanks for the feedback! It's in a 3/4 Ton truck, certainly is original. will be reaching out for parts, Mac!
they make great boat anchors
In my opinion, it looks to be a T9 with a PTO cover on the passenger side
Why brush off both sides of that transmission on the driver side if it says 59T then it’s a 4 speed |
The serial number stamped on the top lip of the transmission bellhousing flange (above the small removable inspection cover) should provide information on the approximate build date.
1935 157" 1 1/2 ton stake truck undergoing full original restoration 1936 131 1/2" panel truck rescue preservation Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America |
You need 2 more of them?
