Old 01-26-2025, 07:30 PM   #1
john worden
john worden's Avatar
Default 29 coupe frame sag?
After attempting to fit the hood to an otherwise sound, older restoration on which the hood was never properly fitted, it appears that the frame has sagged. What are the chances? The gap at hood/cowl widens from pinstripe going down to cowl bottom. It fits well across the cowl top and radiator shell top. The gap is even top/bottom at radiator shell sides. If sagged, it seems that it would happen at, or just ahead of the cowl. Could it be corrected on a frame machine without disassembling the car?
Thanks.
Louvering, bias ply tire-truing, metal shaping and forming, lathe and mill work, member shop HAGERTY Ins. expert repair network. High quality paint work in Iowa.
john worden is offline   Reply With Quote
Old 01-26-2025, 08:09 PM   #2
Harpkatt
Harpkatt's Avatar
Default Re: 29 coupe frame sag?
You can shim the body blocks if it's within reason. But know moving one corner will effect others -trial and error.
Harpkatt is offline   Reply With Quote
Old 01-26-2025, 08:25 PM   #3
jb-ob
One retired body man removed the shock links and wrapped straps over the shock bodies to anchor the frame to the chassis machine before straightening.
One approach.
jb-ob is offline   Reply With Quote
Old 01-26-2025, 08:57 PM   #4
Synchro909
Synchro909's Avatar
Mostly error! It will take a lot of tries to get it right.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 01-26-2025, 08:58 PM   #5
BButturff
BButturff's Avatar
John Hash has been straightening Model A frames with the body on for several decades. Here's a video showing his method.
https://www.youtube.com/watch?v=0YpoDS5ZyyE
Good luck,
Bruce
BButturff is offline   Reply With Quote
Old 01-27-2025, 12:08 AM   #6
john worden
Thank you all. Your input is very useful. John
Old 01-27-2025, 07:27 AM   #7
nkaminar
nkaminar's Avatar
My Fordor had all the symptoms of a frame sag. I lifted the body (4 inches) to take the front fenders off for painting and found all of the rubber pads compressed to paper thin and brittle as a cracker. I replaced all the rubber shims and made some adjustments (more than one shim) to get the doors to fit correctly. While the body was lifted I put a straight edge on the top of the frame and found it was straight. Now my hood fits correctly.
By the way, all the bolts were rusted. I replaced them all with a body bolt kit from Snyder's.
Old 01-27-2025, 08:49 AM   #8
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
I guess I need to call John and ask questions because I have more questions after seeing that video. I understand how his clamping method attaches however I don't understand how the two chains can be adjusted that accurate to make both "frame gauges" be exactly the same length. Most restored vehicles have Frame Anti-Squeak glued down or they are 'stuck' to the frame (-at least from my experiences), so how do you get the "frame gauge" wires under the welt, ...especially with the curvature of the apron in the way. The same thing with the fender and/or radiator apron in the front.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 01-27-2025, 01:02 PM   #9
Joe K
Joe K's Avatar
I would have reservations about any straightening by force by which the force passes "between frame component parts." My fear being loosening rivets, or even forcing a movement between riveted parts. Or even a loss of "rivet tension."
Now to set up a strongback "going the length of an element" and working to that as restraint I have done to an intact frame with the body removed. (hydraulic jacks don't work on their side - requires a "porta-power.")
To stress/force across a riveted joint may imply necessity to "re-rivet" (i.e. "tighten") the rivets - which would probably be done "cold" - not the best effect. ("tensioning" a rivet is best done in the cooling after heating.)
At least part of the key here to success is identifying EXACTLY where the bend is and addressing it most directly - a task best accomplished by removing the body and possibly the running gear.
Not what you want to hear, I'm sure.
Joe K
Shudda kept the horse.
Old 01-27-2025, 01:54 PM   #10
ModelA29
ModelA29's Avatar
Think
ModelA29 is offline   Reply With Quote
Old 01-27-2025, 05:52 PM   #11
Sunny the Model A
Sunny the Model A's Avatar
My pickup has the same sag, partially due to the springs and shackles being worn out causing a lean to the drivers side. I can't fit my fingers under the shackles anymore and the truck has a bend in the frame right around the motor mount. The hood lines up fine, only giveaway I have is a stiff choke rod. I REALLY don't want to pull the body off to fix it, so I guess once I change the shackles and springs then I'll tackle the frame issue
"Ain't but three thangs in this world worth a solitary dime, but A Models, Sweet Tea, and Macaroni Pie!"
Sunny the Model A is offline   Reply With Quote
Old 01-29-2025, 01:59 PM   #12
rotorwrench
rotorwrench's Avatar
A person should try to check the body blocks for extra shims. Some folks shim for door fit and make other problems in the process. Other problems such as the wrong front cross member can require shimming or deshimming of the radiator on the front cross member. It all has to be checked before attempting to bend the frame. Model A frames are flat on top but the bottom flange varies in several places so a person has to think it through. As was mentioned, the frame webbing and the body blocks need scrutiny to make sure the stuff isn't rotten and missing is several spots. Gauges should attach to be flush with the frame top rail or they are won't gauge much. I think sheet metal could be formed to work as long as it will slip under the webbing.
