I just picked up a basket case 8BA engine. 2 cranks, 2 sets of pistons and rods, ETC. This was in the back of an 1949 F1 I just bought. Are truck engines different? How do I identify what block I have? Heads are 8BA.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go?
pencil test....and it looks like those center exhaust ports got overheated with the discoloration I see in your photo.
Check those exhaust valve ports down to the middle coolant hole
The block is a 49-53 8BA. Everything in the picture looks to be 8Ba. I’m not seeing any 59A stuff.
The block, heads and intake look like 8BA or 8RT to me.
Lots of good info on the Van Pelt site
http://www.vanpeltsales.com/FH_web/f...85to100mid.htm 59 series http://www.vanpeltsales.com/FH_web/f...0to125late.htm 8ba/8rt
For all your 221-239-255 Ford flathead identification needs: https://fordbarn.com/forum/showthrea...4280&showall=1
That's an excellent thread, but the O/P's question was : "Are truck engines different?", and since he's asking about an '49 F1, it's way more information than he asked for and actually doesn't even come close to answering his question. (Even though he mistakenly references a "59AB", he is obviously asking about an "8RT" from the picture posted.)
#9 | ||
Yes and no. The original post asked two questions, about any differences in truck blocks and how to identify his block. Quote:
The thread provides the answer to the other question, how to identify the block, by going over how to identify any 221-23-255 block. To provide better guidance we need to know what vehicle this engine is going into. That will dictate what parts are needed to assemble for bolting into the chassis. Last edited by 38 coupe; 01-20-2025 at 07:38 AM. |
In 1948, the 8RT parts and 8BA engine type was released only for light F1/2/& 3 pickups and the trucks through F6. The cars were still the earlier 59A type engines that have the half bell integral to the block. 8BA engines require either a stamp steel or cast iron bell housing depending on model. The 59A may fit into a 1949 F series pickup but it has a fair amount of different parts. The 8BA is the way to go for it.
#11 | |
