Old 01-19-2025, 09:42 AM   #1
Jemelton#
Jemelton#'s Avatar
Default Will your A Start today
It is -18 degrees F here on the homestead. Thinking of going out to the storage barn and seeing if I could get the old girl fired up. what do you think of my chances?
Jemelton# is offline   Reply With Quote
Old 01-19-2025, 09:44 AM   #2
ronn
Default Re: Will your A Start today
slim to none..............lol
Old 01-19-2025, 10:10 AM   #3
Big hammer
If your not going to drive it and get it really warm just wait for a warmer day !
get a bigger hammer tap done
Old 01-19-2025, 10:16 AM   #4
katy
katy's Avatar
Ditto
BTW, What weight of oil is in it?
katy is online now   Reply With Quote
Old 01-19-2025, 11:07 AM   #5
Dale'45
My Dad always told the story about starting his Model A at -40º. He and his brother were working in a logging camp at the time in northern Wisconsin. They would get every other weekend off so the car sat for two weeks outside at a lot in the closest town. They were given a ride in and out on there weekend off. He said one on the crank and one on the starter and the car was running. Long cold ride home though.
Dale'45 is offline   Reply With Quote
Old 01-19-2025, 11:27 AM   #6
BButturff
BButturff's Avatar
I wouldn't do it without a very good reason to. I've started mine at +20 degrees with 10W-30 synthetic and didn't have any trouble, started right up. But I run 5W-20 synthetic in my snow blower and it's very stiff to pull over. Can imagine the A would be much harder. But do let us know if you try.
BButturff is offline   Reply With Quote
Old 01-19-2025, 12:10 PM   #7
Marshall V. Daut
One thing that used to help Model T owners start their balky Tin Lizzies in cold weather (besides jacking up the right rear wheel!) was to fully choke the carb and hand crank the engine for a couple revolutions with the ignition switch off. Then get into the car, turn on the ignition and press the starter rod while choking again. (Be sure to enrichen the fuel mixture maybe 1/2 turn via the GAV!) By pre-fueling the cylinders, you get a head start on providing combustible material right away instead of trusting fuel to reach the cylinders in cold weather by starting the engine the usual way. Cold engines turn over slower than in warm weather, affecting the sucking power through the intake manifold for the fuel to reach the cylinders. Of course, to hand crank and choke the carb at the same time, you either need an extra set of hands or a wire running from the carb's choke lever to the front of the car, which was standard in Model T's. Many Model A carbs have a hole in the bottom of the choke arm for that purpose. If not, simply tie a length of safety wire to bottom of the arm and pull on that.
Marshall
Marshall V. Daut is offline   Reply With Quote
Old 01-19-2025, 12:36 PM   #8
Rob Doe
Ditto Mr. Daut's comments. I can't speak for jet engines, but every piston engine aircraft I am familiar with uses a priming technique before cranking the engine. Cold weather or not, but a much heavier in cold weather.
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!"
Rob Doe is offline   Reply With Quote
Old 01-19-2025, 12:37 PM   #9
Jemelton#
Jemelton#'s Avatar
I stuck my head outside and quickly decided to forget it! The 29 Tudor can continue it's winter nap. By the way, it is stored inside an insulated 12X20' shed which has a ceiling mounted heater. I only run the heater when messing around inside the shed. When running the heater, it will heat the interior quite nicely to 70F or so, at the expense of many KWH of electricity.
Old 01-19-2025, 12:42 PM   #10
Jemelton#
Jemelton#'s Avatar
Marshall
I remember my dad having this choke rod setup on his daily driver. He would always use the crank to start it up in the winter as he did not trust his battery!
Old 01-19-2025, 12:56 PM   #11
Chuck Dempsey
Chuck Dempsey's Avatar
I've just assumed the little round hole on the choke valve was for running a string/wire out the front of the hood. Just in case...
Chuck Dempsey is offline   Reply With Quote
Old 01-19-2025, 01:05 PM   #12
jb-ob
Geesh Marshall you could have saved the lecture and just suggested they read their Owner's Manual, it's in there......but 'real men' don't need no sticking manual !
jb-ob is offline   Reply With Quote
Old 01-19-2025, 02:04 PM   #13
Marshall V. Daut
Who says we can read????
An old-time Ford mechanic friend once chided me after I had made some stupid repair mistake: "I give you books so you can read how to make repairs and all you do is chew off the covers!"
M.
Old 01-19-2025, 02:09 PM   #14
Marshall V. Daut
"I stuck my head outside and quickly decided to forget it! The 29 Tudor can continue it's winter nap."
But aren't you just the least bit curious if you can get 'er started in such weather? If you can get the engine started in this especially cold snap in our fair state, then you'll be sure you can start the engine when the temperature skyrockets up to 10 above!
Marshall
Old 01-19-2025, 04:47 PM   #15
Synchro909
Synchro909's Avatar
Why do you guys live in a place that gets that cold?
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 01-19-2025, 04:54 PM   #16
BButturff
BButturff's Avatar
Ice fishing!!
Old 01-19-2025, 04:55 PM   #17
ModelA29
ModelA29's Avatar
I've started mine here in SoCal when we're in a bone chilling cold snap of the +40s. It cranks slower and needs some more choke but after a few minutes of running lousy and a couple blocks of driving the engine and drive train are warmed up enough to act normal.
PS I must agree with Synchro909........
ModelA29 is offline   Reply With Quote
Old 01-19-2025, 05:05 PM   #18
Marshall V. Daut
"Why do you guys live in a place that gets that cold?"
'Cuz we was borned h'yar! SOMEBODY has to live in this middle part of the country!!!
M.
Old 01-19-2025, 05:45 PM   #19
400A
I once started my old '31 tudor on a rare -13 degree day here in MA, just to see if it would fire up. It did with no problem at all.
400A is offline   Reply With Quote
Old 01-19-2025, 06:05 PM   #20
Gene F
Gene F's Avatar
If you are big on hand cranking, and not using the starter motor....you can cut a piece of 1/2 copper water line. Take an angle grinder and cut a grove down it lengthwise. Then trim it to the final length you want the position to be (like almost closed ~3/4) Once it's done as you like, pull the rod back, and slip the copper tube over the rod in the cab, and go out and crank it.
You can store it in your door pocket, or your workbench.
