Old 01-13-2025, 09:00 PM   #1
50Trucking
50Trucking's Avatar
Default Dropped axle with mechastock parts
Has anyone used a stock model A steering arm with a dropped axle? If you did,how did you bend the steering arm to accomplish this.
50Trucking is offline   Reply With Quote
Old 01-14-2025, 08:36 PM   #2
dalton
Default Re: Dropped axle with mechastock parts
I had my stock axle dropped about 4 inches. I'm using stock spindle/steering arm, and mechanical brakes. The only thing I remember having to do was weld tabs for the brake actuators to bolt to. The steering arm wasn't a problem.
dalton is offline   Reply With Quote
Old 01-15-2025, 05:01 PM   #3
dalton
Well, I guess that must have been a while ago, but I now remember it had to be heated up and bent same as the axle.
