All Model "A" & "B" engines should be restored with:
>Modern insert type main & connecting rod bearings; >Modern stainless steel valves, modern one-piece valve guides & adjustable lifters; >Modern valve seat inserts for all valves; >Light weight modern pistons; >Modern multi-viscosity motor oil with a synthetic blend or full synthetic; >Modern oil seals on the crankshaft; >New 5.5:1 or 6:1 compression cylinder head; >Copper cylinder head gasket; >Stock breaker point ignition; >Aluminum 2-blade fan or plastic 6-blade fan; >Leakless water pump with modern press-fit front bearing; >160F or 180F thermostat; >New reproduction exhaust manifold; >Modern fiber or aluminum timing gear; >Model "B" grind camshaft; >Lightened flywheel & V8 type clutch; >Temperature gauge; >Oil drain plug fitting soldered or brazed to the oil pan so it cannot spin; >Engine side pans: >Popout cable clamp mod to avoid taking off the #8 head nut to remove the distributor; >Edges of all water passages in the cylinder block, cylinder head, the tops & bottoms of cylinders chamfered to remove sharp edges that are crack initiation sites; >Edges of all stud holes chamfered to remove sharp edges; >Static & spin balancing of rotating & reciprocating parts; >Block pressure tested & magnetic particle inspected to detect cracks before rebuilding. What would you add to the list?
Bob Bidonde |
That's your opinion, others may vary.
Lots to object to in this list, but one element folks may not know about is that people are finding the reproduction V8 pressure plates have stiffer springs than they used to, which obviates much of the benefit.
#4 | |
Or so reported... Those with experience with both can report their observations. Joe K
Shudda kept the horse. |
Wow,, mine has been doing ok so far.., with proper maintenance I think it will be running for a long time to come.
#6 | |
The V8 pp did have counter weights on the arms to apply more pressure at higher speeds The Tractor clutch does not have the same counter weights and can have a higher spring rate/preload to compensate Many vendors sell the tractor style not knowing J
As Carroll Smith wrote; All Failures are Human in Origin. |
I like my engine mostly stock, but it has an oil & air filter, a brumfield head, ajustable lifters, and automatic advance distributor.
Inserts or Babbitt are a personal choice.
only an Aluminum or bronze cam gear Best brand 509G graphite head gasket. Full flow oil filter A centrifugal advance Points style distributor, Model B Ford or the new Super B+ Leave the rear slinger alone. I've yet to see a rear main "seal" that didn't drool oil you cant balance a model A crank without adding counter weights. In your heart you know you won't be happy until you have Burtz block kit, head, cam, flywheel an an automatic advance distributor. Last edited by butch chase; 01-06-2025 at 02:15 PM. |
Model A engines should have ? >>>> OIL
Joe B |
The point I was trying to make is, no, those with experience with both will not have useful observations. People who have bought reproduction V8 pressure plates recently, including myself, are finding that they respond differently than V8 pressure plates purchased years ago. And I'm talking about the correct plate, the 09A-7563 plate, not the tractor plate. The springs are too stiff. It's possible vendors are using the tractor plate springs in the V8 plate. Notably, the repro plates omit the insulating washer against the springs, so they must be using different springs than the originals.
This longer release arm makes the stiff V8 clutch work easier. https://www.ecklers.com/model-a-ford...8-24346-1.html
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go?
#12 | |
Get the longer lever from Bratton's https://www.brattons.com/CLUTCH-RELE...uctinfo/11270/ Cheaper too. Last edited by Y-Blockhead; 01-06-2025 at 04:18 PM. |
#13 | |
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan (under reconstruction) 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! |
#14 |
No comment.
#15 |
Counter weights on crank , keep the slinger but use the brass rear main seal.
Dan |
#16 |
Brass seal??? Do you mean BRONZE thrust ring?
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say. I sometimes wonder what happened to the people who asked me for directions. If I am not in trouble, I've done something wrong. |
#17 | |
Bob, not really 'restoring' if you are doing many of those items are you?? ![]() I have offered this before but it bears repeating. Insert conversions are not for everyone. I have another one in the shop right now that has an insert bearing failure. Many are often mislead that once a block has been machined for inserts, then the hobbyist can do bearing maintenance in their own garage without the need for a machinist. More often than not, this isn't the case. It is my experiences that properly cast bearings will outlast insert conversions. |
#18 |
I like babbitt if properly done. I also like inserts if block is properly machined for them. Both have pros and cons.
#19 |
#20 | |
What bearing "maintenance" does one do on an insert bearing motor? |
