Does anyone know/have measured the height of the CG of their Model A?
Google doesn't seem to know. I found a thread from a couple years ago where some had measured the fore/aft location which agreed pretty well with rules of thumb, but not the height. I did find a Model T thread which had a picture which seemed reasonable, but just wondering if anyone knew more exactly. https://www.mtfca.com/discus/message...tml?1283701871
"It is much easier to call someone else a genius than admit to yourself that you are lazy." - Dave Gingery Last edited by Ian Curtis; 12-07-2024 at 05:45 PM. Reason: Accidentally clicked post before I finished writing |
Center of gravity is Weight X Arm = Turning Moment. I've done a lot of W&B on different aircraft and it's really not that complicated but a person needs a good set of scales and measurements for longitudinal and lateral arm locations for weigh points and for the datum which is generally at the front most location of the vehicle. The datum is basically the zero point.
When a person refers to a vertical center of gravity then it gets more complicated. This is considered irrelevant in aviation since they have wings or rotor blades that control the center of lift so vertical CG doesn't come into play. An automobile has the centerline of the axles and spindles that bear the weight of all parts above them. Boats and ships have buoyancy in the water but that changes depending on the load that the boat is carrying. They can roll over in rough seas if the vertical CG is too far above the line of buoyancy. Motor vehicles can also be susceptible to roll over if there is a lot of weight mounted too far above the frame. Big tractor-trailer rigs have more difficulties in this respect due to loading and what can happen in emergency avoidance moves on the roadway. A strong wind can even blow some trailers over at times. I don't really know of a reason to try and measure the vertical CG but the Weight X Arm = Turning Moment still applies but it's figured vertically instead of longitudinally and laterally. Ford was rather unique in their chassis design in the way they tried to have as much unsprung weight as they could get down low. This helps with body roll. They eventually put stabilizer bars on there but that wasn't till 1940 or so. |
Look at the factory assembly line photos that show the body drop. The body support at the drop will give you the horizontal balance point. The CG will reside on vertical plane below the body support point. The CG will vary for each body style.
Bob Bidonde |
Why?
Imagine a roadster with no roof and a Fordor with a heavy roof up high. The Fordor would have a higher CofG than the roadster, quite obviously.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say. I sometimes wonder what happened to the people who asked me for directions. If I am not in trouble, I've done something wrong. |
Your question is kind of confusing …
![]() What exactly are you wanting to know ? Are you wanting to know the height of a specific vehicle from grade ? Based on personal experience transporting over 450 Model T’s and 250 Model A’s of just about every configuration, I can tell you that each is slightly different due to wear and suspension and tires (among other things) … I towed custom built enclosed trailers for many years that had 8 foot clearances at the rear door until covid hit - then I switched to an all aluminum trailer with a rear door clearance that weighed 50% less when empty … Every vehicle I transport is measured before I pick up for height and width and length to make sure it will fit inside my trailer. Jim Transporting To Travel Traveling To Share Stories From The Road |
Steve Smith put a book out years ago called "Advanced Race Car Suspension and Design" if I remember properly. It has everything you want to know about suspension and designing it properly. I think later on it was available on a CD that you could put n the numbers and it would do the calculation.
I put all my weight and balance work ups into the Excell so that all I have to do was add the operational weights such as passengers, baggage, and fuel and it would give me an instant weight and CG.
To do a vertical W&B the car would have to be weighed while on it's side using special fixtures to do the different weigh points that would tell where the CG would be. It's not a real practical thing but it could be done. Fixtures and wood blocks for the scales are considered as tare which can be subtracted from the scale readings for calculation purposes. Model A passenger cars don't have much steel in the roof since most were covered with poultry netting and several layers of fabric & cotton padding. The heavier one would be the big package van types with the fully stamped steel roof such as manufactured by The Budd Company. |
A pretty close guess is often at the height of the rear of the camshaft on many cars.
"It don't take but country smarts to solve the problem" (Smokey Yunick) '30 Model A Speedster '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302
That's gunna be one BIG Christmas ornament.
#13 |
I just thought of a really oddball question in the 5,000,000 model A.'s that were produced I wonder how many feet of paultry netting was used???
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
#14 |
Yeah. Think of all those homeless chickens.
Wayno
Life is not a spectator sport. |
#15 |
If you've nothing better to watch....!https://www.youtube.com/watch?v=42f3Cn6XlSk [and yes, British presenters on tv radio and cinema ( aka movies to you on the other side of the pond) really did speak like that in 1957!]
#16 |
I think there maybe a sales pitch there somewhere these eggs are from homeless chickens as opposed to free range or caged chickens!!!
