Hi guys, I have read up on previous posts Regarding Fitting Flywheel Housing to Motor. - I have a B Pressurised motor which was leaking at the rear Camshaft.
Question -Is it best to fit the supplied Thin Gasket and use some Permatex. Or - Just use some RTV Sealant around the Camshaft Hole. What are peoples thoughts on this. Thankyou |
Don't know about the B, but on my A's, I use the gasket, and when it's torqued down, measure the gap between the block and the two top holes and fit shims of that thickness.
I have had the flywheel housing machined to take an O ring. I then assemble with no gasket, just gasket silicone and no shims at the back of the block.
That has worked well for me.
I sometimes wonder what happened to the people who asked me for directions. Even at my age, I still like to look at a young, attractive woman but I can't really remember why. |
My theory is that the camshaft did not originally come into contact with the flywheel housing or its gasket. However, the thrust surface on the camshaft & block wear, so the camshaft eventually obliterates the gasket and comes into contact with the flywheel housing. Another concern is the camshaft plunger spring. Once the camshaft does come into contact with the flywheel housing, a weak plunger spring allows the camshaft to oscillate fore-aft and make a knocking sound as it slaps the flywheel housing.
Bob Bidonde |
I have witnessed on pressurized motors that if there is no relief it will leak
This can be as simple as using an unmodified groove in the cam bearing or drilling a small hole to vent pressure buildup Another point would be to reduce the amount of oil goes into the bearing at rear J
As Carroll Smith wrote; All Failures are Human in Origin. |
#6 | |
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! |
I personally see no problem with Henry ford's original design but if I chose to upgrade it I would definitely set it up to use the O. ring!!!
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
I second, Henry knew what the flip he was doing. If it ain't broke don't fix it
"Ain't but three thangs in this world worth a solitary dime, but A Models, Sweet Tea, and Macaroni Pie!" |
I looked at a Ford cutaway engine drawing and it shows that the camshaft has clearance to the flywheel housing. I would shim the camshaft at its worn thrust surface with a bronze washer to get at 0.030" clearance to the flywheel housing. At the rear camshaft bearing, I would cut a shallow groove in the bottom of block's bearing journal that is blind to the flywheel housing & open to its front. The groove would give the oil at the camshaft bearing a path to escape back into the engine. In the Model A & Model B engines, the rear camshaft bearing has a voluminous oil supply.
Bob Bidonde |
