Old 10-31-2024, 07:25 AM   #1
cp5491r
cp5491r's Avatar
Default Ampmeter not charging
I'm a novice.
Original 6 volt model A system with generator.
The ampmeter won't show a charge when running/driving the car. It does show discharge when I use the horn. Any likely causes? I replaced the cutout.
Thanks!
cp5491r is offline   Reply With Quote
Old 10-31-2024, 07:50 AM   #2
chap52
chap52's Avatar
Default Re: Ampmeter not charging
Original style generator? If so have you adjusted the generator output by moving the adjustable brushes? Chap
Old 10-31-2024, 09:18 AM   #3
rotorwrench
rotorwrench's Avatar
The modern reproduction ammeters are not as sensitive nor as accurate but they will function adequately. I recommend that folks not use the plastic covered finger nuts and just use regular nuts with lock washers. A loose connection will do damage to the meter.
As was mentioned previously, the 3-brush generator may need the 3rd brush adjusted to a happy place for best function. Ford recommended that an accurate ammeter be placed in the output line when adjusting the amperage output. Some folks adjust for daytime operation and some for night time operation. It depends on how much night driving is done. A person should run with lights on all the time for high output or the battery may be overcharged.
If the generator isn't functioning then it won't show a charge. A person has to make sure it's working so an adjustment of the brush is a place to start. Make sure all connections between the battery and generator are clean and tight. The battery is what regulates the voltage so this is critical.
Old 10-31-2024, 09:37 AM   #4
cp5491r
cp5491r's Avatar
Thanks for those great suggestions. It is an original style generator and the car only gets driven about once a year (I'm bad) so the connections is also a great suggestion. Thanks!
Old 10-31-2024, 10:31 AM   #5
Will N
Will N's Avatar
If the car has sat for a long time the field coils may have lost their magnetism, and you can try to polarize the generator by touching a jumper wire to both sides of the cutout for a second. This will send current through the field coils which will re-establish the latent magnetism in the coil cores.
Will N is offline   Reply With Quote
Old 10-31-2024, 02:09 PM   #6
ndnchf
ndnchf's Avatar
Check out my video in how to adjust the 3rd brush.
https://youtu.be/PL94VX3GIq8?si=evEiDv5hGv7JwIbV
ndnchf is offline   Reply With Quote
Old 10-31-2024, 08:42 PM   #7
Doug Linden
Doug Linden's Avatar
Could be that the cutout is not working. With the engine running put a jumper wire across the two connections on the cutout and check the ammeter to see if it shows a charge.
Doug Linden is offline   Reply With Quote
Old 11-02-2024, 05:55 AM   #8
shew01
shew01's Avatar
Thanks for the link. I’ve read about this before, but it makes better sense now.
