Old 09-24-2024, 08:59 AM   #1
alex31tudor27
Default Model A running issue
Hello All,
I am having an issue with my Model A. I have rebuilt the distributor and re timed my car twice now. I tripled check the point gap and all is ok. However, after driving for about 35-40 minutes the car starts to lose power and backfires regularly. Any idea why this might be? Is it the points, timing, condensor, etc...?
Thanks
Alex
alex31tudor27 is offline   Reply With Quote
Old 09-24-2024, 09:19 AM   #2
Big hammer
Default Re: Model A running issue
First post Welcome to the barn ! When it starts losing power and backfires it sounds to me like your not getting enough fuel flow, remove the gas cap when this happens
get a bigger hammer tap done
Old 09-24-2024, 11:10 AM   #3
Gary WA
Gary WA's Avatar
Or Manifold leak??
www.whidbeymodelaclub.com
Old 09-24-2024, 11:18 AM   #4
WHN
Years ago, I had a similar problem. Car would run fine for 20 to 30 miles and than misfire, just barely run, and no power.
I would check everything including cleaning the spark plugs, which were just replaced. Car would run great again for 20 or so miles and than problem would come back.
Problem ended up being “wrong plugs”. Vendor had sent us the incorrect spark plugs. I installed correct plugs, everything was fine.
I would check your plugs. Are they correct? Are they old and worn out? Is they gap correct.
Good luck.
Old 09-24-2024, 12:52 PM   #5
47topless
47topless's Avatar
Coils and condensers, that are in the final stage of life, tend to work fine when cold but fail when they get warmed up.
47topless is offline   Reply With Quote
Old 09-24-2024, 01:47 PM   #6
Rob Doe
My first thought after reading your intro was the same as Big hammer's. Loosen the gas cap and drive again as he said. It only takes a couple seconds and it's non invasive. If this is happening under acceleration / load conditions, open the GAV. Backfires through the carb are usually lean conditions, but backfires through the muffler and exhaust system are rich conditions.
That said, I've read from knowledgeable folks on this forum that 95% of driveability issues are electrical. That seems to match my experience with the A. Your symptoms would be consistent with increasing heat and or vibration as was also mentioned above. The Model A ignition switch is known to cause backfire / irregular popping noises when it is worn out. Try jiggling the key up and down, in and out a small distance and on and off etc.
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!"
Rob Doe is offline   Reply With Quote
Old 09-24-2024, 05:34 PM   #7
Mulletwagon
Mulletwagon's Avatar
If everything else checks out it would be worth checking the valve lash. My problem was rough idle after warm up. After a major valve lash adjustment (some were way too tight) it ran great and still does five years later. Let us know the fix.
FL Panhandle (hello Helene)
Mulletwagon is offline   Reply With Quote
Old 09-25-2024, 08:17 AM   #8
gdmn852
gdmn852's Avatar
Hello, condensers are a known trouble spot, some of the newer repro are worthless, the location of the condenser gets hot and breaks down, there is a kit to relocate on the point plate to get it away from the heat . Snyders,among others sell it .
gdmn852 is offline   Reply With Quote
Old 09-25-2024, 09:05 AM   #9
Planojc
Planojc's Avatar
Since the problem only happens after the engine warms up, as others have said, change the condenser. If it still has the problem, change the coil.
Planojc is offline   Reply With Quote
Old 09-25-2024, 09:33 AM   #10
Fullraceflathead
Fullraceflathead's Avatar
Most likely your condenser is going out or the coil.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 09-25-2024, 09:58 AM   #11
johnbuckley
johnbuckley's Avatar
x5 first concern is condenser!.....modern repros are notorious for these symptoms when they get warmed up.
Old 09-25-2024, 10:42 AM   #12
nkaminar
nkaminar's Avatar
To test the condensor, change it out. If the performance does not improve, it was not the condensor. To test to see if heat is causing the coil to fail, cool it down with some ice or the spray cooler use in electronics.
Old 09-25-2024, 11:36 AM   #13
David in San Antonio
David in San Antonio's Avatar
When I bought my car the condenser was attached to the firewall on the other side of the bracket that holds the coil. I was told this location was believed to be lower temperature than inside the distributor. It worked fine, though I have no data re temperatures nor the electrical difference of remote mounting.
Late ‘30 Deluxe "Wretched Roadster"
Alamo A’s Club
David in San Antonio is offline   Reply With Quote
Old 09-25-2024, 05:29 PM   #14
nkaminar
nkaminar's Avatar
Mounting the condensor near the coil is probably a tiny bit better than down at the points. The coil and condensor work as a team to generate the spark. It is called an LC resonating circuit. If the LC circuit is working correctly there is no or very little arcing at the points.
