Old 08-08-2024, 02:42 PM   #41
Bob Bidonde
Bob Bidonde's Avatar
Default Re: Vacuum advance dist. for Model A
Find a centrifugal advance distributor instead. The vacuum drops of the Model A engine are extreme. I can imagine what the effect of running the vacuum wiper will be on a vacuum advance system.
Bob Bidonde
Old 08-08-2024, 03:19 PM   #42
AL in NY
AL in NY's Avatar
Bob, a vacuum advance distributor used carburetor vacuum, not manifold vacuum which has less extreme fluctuations.
AL in NY
AL in NY is offline   Reply With Quote
Old 08-08-2024, 04:51 PM   #43
AzBob
A distributor with vacuum advance is primarily controlled by the centrifugal advance bob weight governor. Low vacuum (during acceleration or hill climbing) retards the points plate. When cruising, the vacuum diaphragm advances the timing for improved fuel economy and performance. In other words, a centrifugal advance distributor enhanced by vacuum which is an indicator of engine load.
As Al in NY correctly pointed out, the diaphragm uses a vacuum port above the throttle plates as in the case of my downdraft Weber 32/36. The vacuum diaphragm does not see full manifold vacuum at idle.
The Lucas 25D distributor that Dave of MN modified is a mechanical / vacuum advance type of distributor and works as described above.
AzBob is offline   Reply With Quote
