Old 07-20-2024, 08:13 AM   #1
1021ocean
Default low oil pressure 1934 ford
idle about 1 pound motor sounds good does not smoke at all
1021ocean is offline   Reply With Quote
Old 07-20-2024, 08:45 AM   #2
ford38v8
ford38v8's Avatar
Default Re: low oil pressure 1934 ford
A Ford flathead requires very little oil pressure. A showing on your gauge should put a smile on your face.
Alan
Old 07-20-2024, 05:24 PM   #3
Ggmac
Whats cold pressure? And what oil are you using ?
Old 07-26-2024, 03:38 PM   #4
Karl
Karl's Avatar
Any Oil pressure is good -The Chex Accessory combined Ammeter/Oil Pressure gauge I have reads "" Yes " or "No" for Oil pressure
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is offline   Reply With Quote
Old 07-26-2024, 06:41 PM   #5
Lawrie
Lawrie's Avatar
I can tell you, if any of my flatheads idled at 1 psi I would be worried
Lawrie
Old 07-26-2024, 09:51 PM   #6
GB SISSON
GB SISSON's Avatar
To the original poster... Do you have a bypass oil filter? I recently ran an oil pressure experiment on my V8. Since I had used fuel injection rated 5/16" hose for my return line from bypass filter to sump I was able to clamp a pair of duckbill vicegrips on the return hose and saw a 12 lb instant rise in hot idle oil pressure. My restrictor is intact and on the incoming line to the filter. I'm not saying to run without a filter, but I d I have seen a lot of low oil pressure threads here lately so wanted to share what I found last week. Another thing to check if you are running the stock gauge is the sender. On the current engine I had a 50 lb dash gauge and an 80 lb sender. I found a 50# sender on the engine I had pulled out and oh what a feeling. Pull your sender and if is not marked it's the correvct one and if it has 80 stamped on the square boss, you will in for a happy surprise when you install a 50 lb sender. I hope either of these can help. Worth a try.
Old 07-26-2024, 10:14 PM   #7
51504bat
51504bat's Avatar
Not knowing how long this has been going on or any of the other variables I'd start with a known good mechanical gauge. JMO
Old 07-27-2024, 01:33 AM   #8
tubman
tubman's Avatar
Lawrie
I'm with you on this. There was a thread on here a while ago where someone posted that early flathead V8's were "splash" systems. My response was as close to "rude" as I have ever been on this forum. The old "10 psi per 1000 RPM" is the minimum I'd strive for.
And GB, I'd check the restrictor fitting; it may have been homemade by someone with a minimal selection of drill bits.
Old 07-27-2024, 02:54 AM   #9
aussie merc
aussie merc's Avatar
oil gauges are indicators nothing more, Check where your gauge sits at a range of rpm and sump temps with a good quality test gauge and that should tell the story mine reads 15psi on the dash but a test gauge reads 25 and so one thru the range so Nil to worry about A sudden change would ring alarm bells
aussie merc is offline   Reply With Quote
