I’m using “Best” head gaskets, new Edlebrock aluminum heads. I’m reading that plain old wheel bearing grease is the only sealant I need. I must admit that seems crazy to me, never heard of it before. I’m running out of time on this project so I’m not looking to find problems that don’t exist. Grease yes, grease no?
I used copper coat. Same heads, same gaskets.
40 ford coupe Build -https://www.jalopyjournal.com/forum/...coupe.1277406/ |
I also used a copperhead gasket sealer… permatex as I recall. It was with Offenhauser heads. Never had issues
Coppercoat as well. You shouldn’t have any leaks.
Cooper coat on stock Ford aluminum heads here
I'm a "grease guy" I've also successfully reused head gaskets that haven't been in place too long. I'm also cheap; have you priced a set of flathead head gaskets lately? I have.
I'm a fan of the Felpro composite head gaskets with the heat activated sealer. This is the gasket that Edelbrock recommends with the new aluminum flatheads, so it should be good to use on any aluminum flathead on a cast iron block. It uses the same materials that are designed to seal the different expansion rates of the aluminum heads and the cast iron block. It looks to be the same technology used on modern engines running aluminum heads. The reason I'm sold on them is I was a mechanic for 30-years. The modern engines I did teardown with aluminum heads that had these type of head gaskets and they never showed any corrosion damage at all.
I always spray a very light coat on the gaskets. Let it dry for a little while and then spray a heavier coat on before installing.
I'm a gasket greaser too.
3 moderate coats of permatex copper coat on copper clad composite Best gaskets, stock iron heads, permatex #2 on head bolts. One tiny weep on a head bolt for ten minutes, nothin' since. Yes Denny, the big bore copper gaskets were over 200.00 with tax and shipping. Holy crap!
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
I used 3 coats of aluminum paint. Bought the copper spray, but spoke to a few guys and they said that the copper spray is also a type of glue and the head gasket will attach itself to the head or block or both. I decided to play it safe and use the old tried and true paint.
I also used Hercules thread sealer that I got from a HVAC jobber. Not a drop of water from any of the holes. |
#13 |
#14 |
Grease all my life . My dad used it . He was a mechanic at Singac Ford in NJ in the early 50s and thats what was in use . Are there better now , probably. But why change now if grease works . I would use what ever the gasket manufacturer suggests.
#15 |
Neat. Singac is about 15 minutes from me. I'd assume the dealership was on the main drag.
#16 |
Silver paint three coats on each side works perfectly with copper head gaskets and aluminum heads. Gaskets can be reused many times. My personal experience many thousands of miles doing my head gaskets this way and a few hundred builds for others as well. Every Land Speed record we have set is with silver spray paint many over 200 MPH that's stock block Ford flatheads and ARDUN overhead conversions as well.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587 |
#17 |
I use grease. Makes removal easier if you ever have to open it up again... Chap
#18 |
Thanks for the help guys!
