Old 07-17-2024, 01:56 PM   #1
TomT/Williamsburg
TomT/Williamsburg's Avatar
Default Broken 40 Pickup Drriver Door Latch
My door latch jammed and when I finally got the door open, the piece the grabs the striker plate will not come back out - seems like a spring is broken.
Questions:
1 - does anyone have one for sale that I could purchase?
2 - is there a way to repair it?
3- are there any aftermarket equivalents that I can use?
My truck is all together and ready to drive but I cannot with this broken latch
Any help you can give is appreciated.
TomT
TomT/Williamsburg is online now   Reply With Quote
Old 07-17-2024, 02:25 PM   #2
Karl Wescott
Karl Wescott's Avatar
Default Re: Broken 40 Pickup Drriver Door Latch
If it is a broken spring it should be a fairly straightforward repair. Known "gotcha's": You may have to disassemble the latch by bending folded over tabs. Done cold they will break. Heat them cherry red, then cool and bend. Remove the part, then heat the tabs again and straighten and hammer anneal while red. Then re-install cold. Many vendors will sell a "1938" or "1940" replacement spring, that is good as far as most passenger cars. Pickup/Truck latches often use another spring so you need to go to a vendor who can compare to your original remnants or an original latch with the various replacement springs (I can do that).
The interchange on the latch is 1938-47 Commercial (all pickups and trucks). Not currently reproduced though Drake did at one time.
Karl Wescott is offline   Reply With Quote
Old 07-17-2024, 02:25 PM   #3
ActionYobbo
ActionYobbo's Avatar
The spring is available you need to pull your latch out and match the spring to the picture of what you are buying. Not all 38/39 were created equal. It’s not a hard job to put the spring in until you busy off a tab. Then it’s welding time.
I am building a 1939 1 ton express
ActionYobbo is offline   Reply With Quote
Old 07-17-2024, 03:26 PM   #4
325w
Chuck on here sells correct springs. All springs are not created equal.
325w is offline   Reply With Quote
Old 07-17-2024, 03:30 PM   #5
TomT/Williamsburg
Thanks, gents. It’s a bummer to be hung up by just a spring ….
Old 07-17-2024, 07:10 PM   #6
ActionYobbo
You don’t know until you pull it out. Could be a worn part let the spring slip off. I recently rebuilt my latches and there was a lot of wear on the camming surfaces that I welded up and reprofiled.
https://www.fordbarn.com/forum/showthread.php?t=338145
Old 07-19-2024, 10:26 PM   #7
nutter_Ford_guy
my 40 had the latch pull too far in, past the door sheet metal. Was able to pry it away from area holding it and it popped out. I never pull too hard on the handle anymore. Hasn't done it again in last 10 years.
nutter_Ford_guy is offline   Reply With Quote
Old 07-20-2024, 10:42 AM   #8
19Fordy
19Fordy's Avatar
A Fordbarn search reveals lots of information re: your latch problem and how to fix it.
Start here:
https://www.fordbarn.com/forum/searc...rchid=39720633
Old 07-26-2024, 10:37 AM   #9
TJ
TJ's Avatar
Try to repair what you have as it is a very hard latch to find in decent shape.
Old 07-26-2024, 10:54 AM   #10
rich b
rich b's Avatar
Not to bad of a spring to replace. Just take care with the tabs as previously posted. Obviously this is a R/H latch; but the L/H is a mirror image.
