![]() I have a question about 1955-1956 Ford Full Wheel Covers. Take a close look at this near mint Wheel Cover for the 1955 and 1956 Fords. You will notice that the hole for the Valve is located at the bottom when the Crest is displayed correctly. Now, if you want to display this wheel cover on a hook through the Valve Hole, the Crest will appear upside down? My question is:- Is the Crest mounted correctly in the above example? I personally believe that this is how they originally were supplied by Ford. Would love to hear what the experts have to say on this topic. |
If the '54 is a good indication yours is correct. All four of mine have the hole directly beneath the crest.
'54 Skyliner. As close to original as I could restore it to. |
Not an expert but yours is exactly like ours are on Cathy's 1955 Club sedan.
I think the reason is to have appear the insert as to proper display position (up) with the valve stem at the bottom. Same with styled wheel center caps.
In the olden days ... ![]() Don't ever ask me to put a set of IGN WIRES on the engine as it usually took me three days to get everything lined up and perfect ... ![]()
***** "Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'." ― Charlene Darling (Daughter of Briscoe Darling) |
![]() I'm with you GLAmes, as you can see from this picture. This is my display of 53 - 54 - 55/56 Ford Hubcaps. In every case, the Crest is upside down, supporting my assumption. |
Now I don't know if the oddball ones are Ford replacement or original
![]() Close up - Tags supporting Plastic Centre. From this view, it appears that the Centre can only be installed in 4 different positions. |
