Old 06-16-2024, 01:58 PM   #41
Bob C
Default Re: Rear Diff Plug HELP
Originally Posted by Gary WA View Post
Any Results on removing Plug??
See post #21.
Old 06-16-2024, 03:33 PM   #42
J Franklin
J Franklin's Avatar
Use the plug sold for that application. The housing is unlikely to have been modified.
Old 06-16-2024, 03:59 PM   #43
Gene F
Gene F's Avatar
Post #27 yes.
Are you a local model A chapter member?
Old 06-16-2024, 05:15 PM   #44
Diastole
Diastole's Avatar
Thanks for all the help.
Yes the plug removal process went smoothly, following y'all's advice. Attached are some final pics for those who have messaged and posted.
Yes I am in a club (a great one, with awesome resources), and I went to them first:
1) check with Ford Barn
2) email the MAFCA technical director
3) I am not sure
4) sounds like you got a great plan
I had a set of NPT taps. I ran them in and boom! no resistance and no chips. Threads were fine.
The Snyder's plug screwed right in with teflon tape.
No leaks after running her for about 10 miles.
Diastole in the Smokies
A little learning is a dangerous thing.
Drink deep, or taste not the Pierian Spring;
There shallow draughts intoxicate the brain,
and drinking largely sobers us again.
Diastole is offline   Reply With Quote
Old 06-16-2024, 06:02 PM   #45
Gene F
Gene F's Avatar
3) I am not sure
Good for you. I am a but surprised that one or two of them did not offer to come over and take a look and give you their experiences....
Old 06-17-2024, 09:35 AM   #46
Tom F OHIO
Tom F OHIO's Avatar
Are the plugs suppose to be painted black or not?
Tom F OHIO is offline   Reply With Quote
Old 06-17-2024, 10:15 AM   #47
Bob C
The Judging Standards say unfinished or raven.
Old 06-17-2024, 10:38 AM   #48
German guy
German guy's Avatar
Mine was screwed in so hard that almost nothing worked until I filed two edges off and it fit a hex ratchet with two good surfaces to get it out. Then bought a replacement from one of the usuals. Worked a charm. No idea why anyone would screw it in so tight except that...of course they all leak a few drops a week.
German guy is offline   Reply With Quote
