Old 05-27-2024, 08:53 AM   #1
dsarge390
dsarge390's Avatar
Default Crank hole cover rivet
Another rivet question….
I’m assuming there is a set of tools used o install the crank hole cover rivet. Anyone know the type/size?
Thanks!
dsarge390 is offline   Reply With Quote
Old 05-27-2024, 09:09 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Crank hole cover rivet
Thanks!
Well, there is ...but you probably won't like the price of it. Search for 'Tonka Rivet Tool' and you will see what comes up.
The issue generally is unless the rivet is set uniformly around the edges, the crank hole cover will either be too stiff to turn, -or it will rattle from being loose.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 05-27-2024, 09:25 AM   #3
oldspert
oldspert's Avatar
My crank hole cover was very loose too. I have some split rivets that I used to replace the loose ones. Worked great except that they are tight, and they are stainless. PM me and I will take a pic.
oldspert is offline   Reply With Quote
Old 05-27-2024, 11:38 AM   #4
alexiskai
alexiskai's Avatar
I had a loose cover and I fixed it - at least for now - using a small o-ring. Took some work to wedge the ring under the rivet edges on the back of the shell, but it’s holding for the moment.
Old 05-27-2024, 12:16 PM   #5
nkaminar
nkaminar's Avatar
A method to reduce the precision required is to use one of those spring washers. There are two types, conical and the ones that look like a potato chip.
Old 05-27-2024, 12:50 PM   #6
Steve Schmauch
The crank hole rivet was originally a tube rivet. Originally installed on the back side of the shell was a small flat washer and a small lock washer. It is the lock washer that provided the proper tension after the rivet end was set. Use light taps and check after each tap to achieve the right tension.
No special tools are necessary. Use a proper sized drill to drill a divit into a block of steel or similar and hold in a vice. Use a round, pointed chisel to spread the rivet end and finish with a flat drift. Use tape on the rivet head during this process if you do not want to mar the finish.
Steve Schmauch is offline   Reply With Quote
Old 05-27-2024, 05:55 PM   #7
dsarge390
dsarge390's Avatar
Thanks. The tool isn’t cheap, but this won’t be my last “A” either. Maybe. Ican do a few for people and recover some costs. Looks like it’ll do some other rivet jobs like the hood leather corners, etc.
Old 05-27-2024, 05:55 PM   #8
dsarge390
dsarge390's Avatar
Thanks Steve. I’ll experiment with that technique too
Old 05-28-2024, 04:42 PM   #9
rotorwrench
rotorwrench's Avatar
Tube rivet sets are available in different shank diameters but they require care in the bucking process.
