Old 05-25-2024, 08:45 AM   #1
Juergen
Default Brake stud repair tool
One of the studs for my 35 Ford drum is missing I have a new stud and have to fix it in place (swage it?). How does this tool look? i have a half inch pipe that I would think could be used if I v'd the end (to what angle?) Do i relieve the inside a little to leave some of the 1/2 to 5/8 shoulder of the stud alone? Also I think I need to harden the "pipe". Do I just get it red hot and then cool in oil? Finally is the swage pressed in place or hammered in place?
Juergen is offline   Reply With Quote
Old 05-25-2024, 10:09 AM   #2
Bob C
Default Re: Brake stud repair tool
Here is a link to Vince's site showing how to swage the stud.
https://www.fordgarage.com/pages/swaging.htm
Old 05-25-2024, 10:14 AM   #3
Newc
Newc's Avatar
The cast iron [steel] drums do Not like oversize stud knerlled pressing. Broke a '39 drum here. Swedging is ok, but not the knerled studs. Newc
Old 05-25-2024, 10:58 AM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
Thanks Bob, good info. I've removed a lot of swagged studs to separate hubs and drums, but have never but a set together by swagging new studs in place.
John
Old 05-25-2024, 11:05 AM   #5
Kurt in NJ
Kurt in NJ's Avatar
I have made a several use tool out of a wristpin with appropriately sized center hole , think it was a Chevy or Ford 70s v8, ground it to the shape it the real tool. —-after 3or 4 uses it deformed enough to be not usable .
Old 05-25-2024, 02:04 PM   #6
Juergen
Thanks, Bob, for the link. I mistakenly thought the swedge worked like a pop rivet, just providing a fattened end to hold the stud in place. Instead I see it compresses the stud in the hole almost like a hot rivet. Now to find a 25 ton press.
Old 05-31-2024, 08:32 PM   #7
Dec211975
Mac has the swedging tool listed on their site for $ 17.00.
Dec211975 is offline   Reply With Quote
Old 05-31-2024, 10:01 PM   #8
jplutz
jplutz's Avatar
Greetings, I had to remove & replace all my front studs because my drums were worn out. Attached are photo's of the tool I used to install the new studs in the front hubs. The tool # is 22800, regardless of who sells it.
It has an internal sealed bearing that the body rotates on. The stainless side goes against the hub - you insert the stud from the backside of the hub - you put the tool over the stud, and screw the lug nut into the pocket. At this point, I used a battery impact driver and an Impact socket from Harbor Freight. I tightened it till the stud head was flush against the hub.
I bought the tool on E-Bay(actually, 2 tools because someone complained that they wore out easily).
Well, I installed 10 studs with no problem with one tool, and all with the impact driver. The stud in the photos is an old one with swage cut off with a hole saw.
I did not reswage the studs. A member from the West coast PM'd me and said that once the stud is seated and the wheel installed it is secured.
So, best of luck repairing your stud.
Yours Truly, JP Lutz.
jplutz is offline   Reply With Quote
Old 06-01-2024, 08:18 AM   #9
Juergen
Thanks for the input. I checked ebay and the price is right.
