Old 03-25-2024, 10:50 AM   #21
Kube
Super Moderator
Kube's Avatar
Default Re: Spring removal and Columbia installation
Originally Posted by dean333 View Post
Kube, I’m sure you meant removing the RIGHT axle housing.
I don’t know what you consider “easy”, especially if it’s up on jack stands. Adjusting the gear mesh pattern is an all day job….taking it apart at least three times to get the proper shim thickness. I can’t imagine doing that on your back as well as everything else. Everyone I’ve talked to says it’s an eight hour process.
I did misstate. Actually, both housings must be removed. Thanks for the catch. I didn't mean to add confusion to this thread.
Eight hours? I can imagine that if a guy is doing this for the first time.
I'd installed so many of these, it's a fairly easy process for me. Getting up and down not so much anymore
Old 05-04-2024, 09:32 PM   #22
SoCalCoupe
SoCalCoupe's Avatar
I am unbelievably slow but making progress. Bought an additional pair of jack stands last month then went on vacation. Borrowed a spring spreader from a fellow EFV8 club member.
Spent the morning in the garage and detached the spring, removed the other hub and both backing plates. Was concerned about making a mess with brake fluid but didn't. Just put a paper towel under the brake line as I was disconnecting it and caught the couple of drops that leaked out.
Had to stop because I couldn't remember how to disassemble the axle. Looks like I need to drain the oil then remove the LH housing and RH housing. Then the axles come out after I remove the housings.
The differential drain and fill plugs are badly rounded out. I'll buy some new ones. I'll wrap my 3/8" drive in shim stock to wrench out the existing ones so I don't strip them out completely. Looks like I'll also have to buy some lock-wire for reassembly of the internals.
SoCalCoupe is offline   Reply With Quote
Old 05-05-2024, 03:38 AM   #23
deuce lover
deuce lover's Avatar
The axles are all connected with the carriier along with the ring gear. It all comes out the left side after removing the left axle housing . Then remove the right axle housing.
Old 05-05-2024, 06:27 AM   #24
glennpm
glennpm's Avatar
Agree that this is the worst part. I did mine on a workbench and wouldn't want to do it under the car. Parts get heavier as I get older :-)
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 05-05-2024, 06:44 AM   #25
Bored&Stroked
Bored&Stroked's Avatar
Getting the backlash and gear mesh correctly set is really important for the overall noise and life of the gears. Preload on the pinion is important as well - though you're probably not taking the pinion out of the banjo, so you might get away with leaving it alone.
I can't imagine doing it on the floor of my garage and actually believe it would not be easy to know you had it correctly set. I'd take the whole unit out of the car and work on it where you can really see what the heck you're doing.
I make a wooden "box" out of 2" x 6" boards and stand 1/2 of the unit on it (no axles in it) - vertically (with backing plate on). Now that it is supported and about waist high, I can work on the setup of the gears and differential (side gaskets) to get the gear mesh where it needs to be. Once this is all correctly setup, then I put the whole unit together with the axles.
I also made a plate that picks up the banjo bolt-circle - so I can work on the unit on an engine stand. This makes a lot of the work a bit easier as well. The only bad part is my stands are not tall enough to completely rotate the unit . . . Oh well!
Old 05-05-2024, 12:17 PM   #26
motordr
Oh boy Dale, that Chuck key.
motordr is offline   Reply With Quote
Old 05-05-2024, 02:14 PM   #27
petehoovie
petehoovie's Avatar
Old 05-06-2024, 06:24 AM   #28
Bored&Stroked
I usually never leave it in the lathe . . . but I guess I did on this particular day! LOL
Old 05-06-2024, 06:31 AM   #29
motordr
I’m sure that it wasn’t you, must have been your helper. lol.
Old 05-11-2024, 06:10 PM   #30
SoCalCoupe
SoCalCoupe's Avatar
Stuck again. Can't remove the axle keys to get the housings off over the axle.
This link seems like a good FordBarn thread but neither the center punch, dykes, or vice grips are working for me. I REALLY don't want to move to the cutting wheel stage.
Old 05-11-2024, 07:27 PM   #31
ford38v8
ford38v8's Avatar
Originally Posted by SoCalCoupe View Post
Kube, Thanks. I can afford the best jack stands; not sure what those might be, so much cr@p made in Ch!n@. Not a Harbor Freight fan at all. Just don't know where else to go for jack stands. Pretty simple product. But, willing to pay for the best to avoid having the car fall on my face.
Yes, Columbia conversion seems pretty easy all things considered. Really enthusiastic about this project.
About jackstands, there are lots of choices, but one feature to look for in a good jackstand is a solid, flat base. 4 legs on the ground will not support the weight, one or two legs sink into the asphalt, which tends to ruin your day.
Alan
Old 05-13-2024, 05:38 AM   #32
38 coupe
38 coupe's Avatar
Did you get the keys out? One thought I have had in the past, but never had to resort to doing, was to carefully grind the top of the key down enough for the axle housing to slide off. I figured once the axle shaft was separate I could weld something to the key and pull it out without worrying about weld splatter on anything else.
Old 05-13-2024, 09:28 PM   #33
SoCalCoupe
SoCalCoupe's Avatar
No, I haven't got them out yet but that's a thought.
I have to work this week but come the weekend I'll go at it again. I'm a tool junkie and ordered another tool which should arrive Friday, 12" nippers. I'll try ice on the key to shrink it then try to pull it out with the new high leverage nippers.
Wish me luck.
Old 05-13-2024, 10:50 PM   #34
ford38v8
ford38v8's Avatar
To remove a stuck key, use a drift pin (not a center punch) and mallet to tap the key inboard and up the ramp in the axle. The key has nowhere to go but up and out.
Alan
Old 05-13-2024, 11:05 PM   #35
SoCalCoupe
SoCalCoupe's Avatar
That's a thought. I have to work this week but come the weekend I'll go at it again. I'm a tool junkie and ordered another tool which should arrive Friday, 12" nippers. I'll try ice on the key to shrink it then try to pull it out with the new high leverage nippers.
Wish me luck.
Old 05-30-2024, 04:41 PM   #36
SoCalCoupe
SoCalCoupe's Avatar
Unbelievable. Countless hours over the past 19 days and now the axle keys are out. One of the guys in my Early Ford V8 Club has lot's of experience with this. He came over with his own chisel with the right skew and right bevel, held his mouth just so, swung the hammer just right, and got them both out in less than 10 minutes. Didn't even get his hands dirty.
This guy's worked on dozens, maybe hundreds, of flathead race cars and said he's never been defeated by an axle key. His record is intact!
Might get this Columbia done yet.
Old 09-07-2024, 11:34 PM   #37
SoCalCoupe
SoCalCoupe's Avatar
OK. 3 months later I might be back on track. Got REALLY stuck on installing a spring shackle bushing on my Columbia housing that was delivered without any. Really want my flathead back in commission and have fun driving. This afternoon, after a local car show with another car, I bolted up the Columbia to the rear end center section. Have to make sure that I've got it clocked correctly to the right bolt holes. The alignment of the spring shackle and radius arm brackets seem spot on but the fill level indicator on the Columbia seems higher than the fill hole on the differential. Also, I expected the flat surfaces of the Columbia to be parallel and perpendicular to the ground but they're clockwise forward as if I've bolted it up one hole off. I'll figure it out though. Just glad to get unstuck and start getting the car back together.
Old 09-08-2024, 06:51 AM   #38
glennpm
glennpm's Avatar
Make sure that you have the center section to axle housing shim gaskets figured out. You can't just bolt it together without doing this step. B&S mentioned it in post #25 above.
Instructions are located in post #6 of this Barn thread, "HOW TO PROPERLY SET UP 1928-1948 FoMoCo and COLUMBIA REAR AXLE ASSEMBLIES USING THE GASKETS AS SHIMS"
https://www.fordbarn.com/forum/showthread.php?t=250383
Glenn
Rumble Seat’s Notes
Old 10-12-2024, 04:06 PM   #39
SoCalCoupe
SoCalCoupe's Avatar
Anyone know what torque I should use to bolt the ring gear to the Columbia differential case? The bolts are 3/8"-16 and heads have no marking except for the letter "M". The typical torque spec for a Grade A bolt with these threads is 10 ft-lbs. Seems awfully light but maybe that makes sense since they're also secured with lockwire.
Old 10-13-2024, 08:50 PM   #40
danliveshere
danliveshere's Avatar
You can also get onto John at Columbia 2speed. I’m not sure where you purchased your Columbia axle but John is the go-to guy for all your new Columbia parts etc.
https://www.columbiatwospeedparts.com/
danliveshere is offline   Reply With Quote
