Old 04-19-2024, 12:58 AM   #1
Brian
Brian's Avatar
Default oil type recommendation
I'm converting a Lincoln [hypoid] rear end to Columbia, hypoid rear ends have special additives, the Columbia contains yellow metal components. So, what oil specification do I put into this thing? Thanks, Brian
Old 04-19-2024, 09:15 AM   #2
19Fordy
19Fordy's Avatar
Default Re: oil type recommendation
GL-4 is highly recommended.
Read about it here:
https://www.fordbarn.com/forum/showt...=rear+end+lube
O'Reilly's sells it.
Old 04-19-2024, 09:20 AM   #3
19Fordy
19Fordy's Avatar
Sta Lube GL4 is highly recommended.
https://www.crcindustries.com/api-gl...ear-oil-1-gal/
Also available in 140W.
I buy mine at O'Reilly's.
Old 04-20-2024, 01:22 AM   #4
aussie merc
aussie merc's Avatar
im with 19fordy a GL4 in 140w whose? well thats your choice
aussie merc is offline   Reply With Quote
Old 04-20-2024, 02:22 AM   #5
Brian
Brian's Avatar
Cheers boys...I'll go with Penrite 'Mild EP', won't harm bronze, suitable for early hypoid gears.
