The rebuilt transmission in my 1932 Coupe shifts nicely when driving the car. However, sometimes it is difficult to shift out of gear into neutral when the car is on a slight hill and I have come to a stop. I have to gently let out the clutch and "lurch" the car slightly to unload the drive train to get the transmission into neutral. I have taken the top off of the transmission and with the car sitting in the garage, you can slide each gear very easily with your fingers. It is a nuisance. What is causing this problem? Thanks, Ed
Clutch drag???
Is this a '32 type trans with straight cut teeth or a later with a helical tooth cut? The straight could be harder to shift when "loaded" by the drive line.
Paul J. |
What weight oil/lube are you running in the tranny??
Paul in CT |
I am using heavy gear oil, 600W. The gears are helical. What transmission oil would you recommend? Ed
Ed,
What Dave says. Any good grade 85-140 weight will probably remedy the jam. Charlie ny |
Thank you for the recommendation on using the lighter oil. I will give it a try. Ed
