Old 04-03-2024, 11:25 AM   #21
petehoovie
petehoovie's Avatar
Default Re: What did you do today that was flathead V8 related?
Originally Posted by Ziggster View Post
Been messing with the copper coolant pipes for my rear mounted rad on my speedster project for the last month and a half. Trying to make a mount/support using the fuel pump/breather tube for the copper pipes coming off of the heads.
Old 04-11-2024, 10:35 AM   #22
ndnchf
ndnchf's Avatar
I went to the Charlotte Auto Fair last week. I came home with a pile of generator cores for rebuilding. So I've been going through and sorting them out.
ndnchf is offline   Reply With Quote
Old 04-11-2024, 10:49 AM   #23
petehoovie
petehoovie's Avatar
Old 04-11-2024, 11:01 AM   #24
BoxCar Tom
BoxCar Tom's Avatar
In response to a Want Ad I spent at least 2 hours last night taking pictures of two disassembled 32 column "drops", then move the pictures to my computer to reorient them, then move the pictures to an email, then write an email with an accurate description of each drop. Well what else am I doing from 11 PM to 1 AM?
BoxCar Tom is offline   Reply With Quote
Old 04-11-2024, 11:10 AM   #25
petehoovie
petehoovie's Avatar
Old 04-11-2024, 08:13 PM   #26
TonyM
TonyM's Avatar
I wrote a check.
TonyM is offline   Reply With Quote
Old 04-11-2024, 08:21 PM   #27
TomT/Williamsburg
TomT/Williamsburg's Avatar
I drove mine all over town today!
TomT/Williamsburg is offline   Reply With Quote
Old 04-11-2024, 09:00 PM   #28
RalphM
RalphM's Avatar
Got the interior out and most of the floor cleaned up on the 47 Coupe. Just going to wire brush it, replace body seam caulking, and POR it.
Replacing body mounts at the same time.
RalphM is offline   Reply With Quote
Old 04-11-2024, 11:17 PM   #29
petehoovie
petehoovie's Avatar
Old 04-11-2024, 11:28 PM   #30
tubman
tubman's Avatar
Logged into "The Ford Barn" about 6 times!
Old 04-12-2024, 12:18 AM   #31
deuce_roadster
deuce_roadster's Avatar
Only worked on Brand X today but like tubman, logged on here.
Old 04-12-2024, 06:53 AM   #32
BoxCar Tom
BoxCar Tom's Avatar
Only 6 Times?
Old 04-12-2024, 10:46 AM   #33
Scott52
Moved car back to my garage from storage. My wife will make the seat covers and the engine is getting ready to go back in.
Scott52 is offline   Reply With Quote
Old 04-12-2024, 10:48 AM   #34
Scott52
Oh and I had to move the Dodge Power Wagon (230 Flathead) out of the garage to make room.
Old 04-12-2024, 12:36 PM   #35
Newc
Newc's Avatar
Drove 60 miles to looook at a Free pile of mechanical parts, then drove home. Just not worth messing with 5 pallets of mechanicals. Even a Y block 292" Trk 4 speed too. Newc
Old 04-12-2024, 12:49 PM   #36
petehoovie
petehoovie's Avatar
Old 04-13-2024, 04:21 AM   #37
1934
1934's Avatar
I got the '34 out of the barn yesterday after it's winter rest. It didn't want to wake up at first and was a bit cranky, LOL. A bit of gas down the carb and she perked right up! There was still a bit of residual salt on our roads here so I didn't go for a drive. I changed the oil and it rained quite a bit last night so maybe I'll put a few miles on it today.
Doug.
1934 is offline   Reply With Quote
Old 04-13-2024, 04:39 AM   #38
ndnchf
ndnchf's Avatar
I was working on a local club member's generator. It had a threaded on, fan mount pulley. These are often tight and a bear to remove. Being a fan mount pulley, I was able to unscrew it using an old fan as a wrench with the armature in a padded vise and a little heat.
Old 04-13-2024, 09:12 AM   #39
farmertom
farmertom's Avatar
well,i drive my,'37 daily at least for 30 mins to hour or so. couple days ago got her up on all fours and performed all maint. oil change,lubed zerks,springs,checked trans.,diff,oiled gen.and,distributer. also new coil and condenserTom.
farmertom is offline   Reply With Quote
Old 04-13-2024, 09:59 AM   #40
petehoovie
petehoovie's Avatar
