#121 |
It seems to me a lot easier to go with an open drive conversion. We've done about twenty of them at American Iron and they work well. I do give credit to the torque tube project that's a great engineering feat.
#122 |
Subscribed
Well done Gents!!! |
#123 | |
![]() Quote:
I sincerely appreciate the kudos on the torque tube adaptation. Quite a few folks express similar opinions about going open drive. Admittedly, the banjo rear can be a little weak, or fragile, but that can be overcome with a later Ford splined axle re-do. Once you really take the time to realize what a genius engineering concept the banjo rear really is with it's torque tube and radius rods and attached spring pack, it's a design that I prefer to work with when at all possible. When a banjo rear is installed with all of it's original appendages intact, it is just amazing how that suspension articulates in the chassis. DD . |
#124 |
Hard to believe no one has dug this thread up since 2021. This is the first time I have seen it. As others have already said Great work by Heard and v8coopman. The t5 is a flatheads best friend IMO. And I agree with V8coopman 100% about the design of the Banjo/Torque tube rearend. Once you really study the way the suspension works and works well on a early ford torque tube setup. It's hard to beat it IMO.
#125 | |
![]() Quote:
#126 | |
I have referred several people to this tread and I'm sure I am not the only one to do so. |
#127 |
I am trying to think this one through, I have read a few other T5 threads lately that make reference to close ratio combinations. It seems to me that with the width of the power band of a stock flathead, five gears would be two too many, until you add in the over driven fifith of course.
Nearly 50 yrs ago I had a 1966 mustang, 289, 3spd manual, 2.80:1 rear end. It was not a combination that many people wanted, but other than its poor handling and shocking brakes the car drove well. I have allways thought that gear box would be great behind a flat head. Geoff |
#128 | |
![]() Quote:
#129 |
I certainly agree with the design and building of this system. Far beyond my abilities Never had much money for my Hot Rod hobby, Wife and four kids came first. Working in Ct I came across used machinery in junkyards, that did the jos, and my employment had me running allot of machenry. But!! I know my lininations. I also like Making things. As for the banjo rear?? That was eliminated in my drag racing days, when the Oldsmoble engine ruled the rust, and I never went back. However we used a banjo rear in the stockcar, and it failed when keading the fecher!!!! But that was my fault!!! On this rear I haden't installed the pinion snubber yet. Modern rear axles are cheap and offer better brakes and posies. and this improves our cars for less money. I try to give others a better, cheaper option for their ride, so they can make the wife and kids happy!
Gramps |
#130 | |
![]() Quote:
#131 | |
![]() Quote:
#132 |
The person that ventures into this hobby, need options, and that depends on his abilities and finchael situation. Never having any money, everything came out of junkyards. Installing a different rear axle in your early ford meant that you welded the spring brackets from your old axle on to the new axle and a homemade latter bar to the trans mount along with the new trans which could be a Packard or caddy or some other 10 dollar box. I don't remember most of the stuff.
Gramps |
