Old 02-06-2024, 02:48 PM   #1
dean333
dean333's Avatar
Send a message via Yahoo to dean333
Default LED bulbs
New LED’s really bright with inside of housings painted white.
Tim Carlig
dean333 is offline   Reply With Quote
Old 02-06-2024, 04:05 PM   #2
19Fordy
19Fordy's Avatar
Default Re: LED bulbs
Which photo is the LED.? Photo on left looks like it's not red. Might be the camera.
Old 02-06-2024, 05:45 PM   #3
dean333
dean333's Avatar
The one on the left looks brighter because of the light shining through the clear part of the top of the lens to illuminate the license plate.
Tim Carlig
Old 02-06-2024, 06:32 PM   #4
Model51
Model51's Avatar
What's a good source for the correct LED bulbs? I've used Classic and Vintage Bulbs (located in Australia) but haven't received any reply to emails about buying more bulbs. I found LogoLite but haven't tried them. Any suggestions for a good supplier?
1935 157" 1 1/2 ton stake truck undergoing full original restoration
1936 131 1/2" panel truck rescue preservation
Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America
Model51 is offline   Reply With Quote
Old 02-06-2024, 06:51 PM   #5
dean333
dean333's Avatar
I got mine from Amazon, $50 off of you get an Amazon Visa card and free returns. Also from LBCarCo.com
Tim Carlig
Old 02-06-2024, 07:20 PM   #6
Ken/Alabama
Ken/Alabama's Avatar
Yes, got them in my 40s.
Old 02-06-2024, 07:41 PM   #7
pbsdaddy
pbsdaddy's Avatar
Just remember, when you use LEDs for turn signals, they work much better with the proper flasher unit. The flashers are easy to get. Any truck stop or truck supply outlet will carry the correct one. They don't work with 6 volt applications and I found with my 49 F1, I had to bump the idle speed up just a little, to get them to flash properly.
pbsdaddy is offline   Reply With Quote
Old 02-06-2024, 07:45 PM   #8
Dan in MI
Dan in MI's Avatar
Try LEDLIGHT.com They have the correct 6 volt positive ground bulbs and flasher.
Dan in MI is offline   Reply With Quote
Old 02-06-2024, 08:10 PM   #9
drolston
drolston's Avatar
What!? They have LEDs that fit dash light sockets!. Do they have 12v positive ground?
Unless the sun is over my shoulder, I have to use a flashlight to read the gauges on my '41. Maybe because of low contrast between red needles and gold/amber instrument face. Maybe because I need cataract surgery.
Old 02-06-2024, 09:26 PM   #10
Ken/Alabama
Don’t know about 12 volt. Mine are 6 volt and fit in the sockets just fine.
Old 02-07-2024, 08:42 AM   #11
Model51
Model51's Avatar
Thanks for the additional vendor names. Looks like most of the bulbs are both positive and negative ground and also 6 and 12 volts so they should work in most applications.
Old 02-07-2024, 10:07 AM   #12
51woodie
51woodie's Avatar
It's good to know who the vendors are, but part numbers would be helpful as well. I find it is better to have information from someone who has used/fitted the specific part, than looking in a catalogue or on line, and ordering something that may not work or fit.
51woodie is offline   Reply With Quote
Old 02-07-2024, 09:42 PM   #13
drolston
drolston's Avatar
Source? Part number? Thanks!
Old 02-07-2024, 10:06 PM   #14
Ken/Alabama
Got them on Amazon .
Old 02-07-2024, 10:24 PM   #15
petehoovie
petehoovie's Avatar
Old 02-07-2024, 11:03 PM   #16
jers36
jers36's Avatar
I just replaced my tail light bulbs in my 36 pickup purchased from ledlight.com'
original # 1129 use 68576 1 1/2" long or 97869 approx. 2" long the 97869 is the brightest but is a tight fit between the socket & lens be sure and check it.
Original # 63 use 78747 both of these replacements are 6 volt and are straight pin single contact. They work fine
jers36 is offline   Reply With Quote
Old 02-08-2024, 05:29 AM   #17
ndnchf
ndnchf's Avatar
This is where I got mine too (not to be confused with LEDlights.com which is a different company). I also got their LED compatible flasher. My 6v positive ground lights are great, the turn signals work fine and the generator output is set very low, yet still provides a positive charge with the lights on. Its a win-win situation ��
ndnchf is offline   Reply With Quote
Old 02-08-2024, 08:24 AM   #18
Merc Cruzer
Merc Cruzer's Avatar
LedLight.com
P.O. Box 82626, Phoenix, AZ 85071
Business Hours
Phones and Live Support
Toll Free (877) 283-5060
Local (602) 997-0366
9am-3pm Monday-Friday (MST)
Contact by Email
SALES & SUPPORT - [email protected]
Contact by Phone
Contact by Fax
Fax 1 (602) 861-4088
My headlight, tail light, flasher, dash light ans fog light bulbs all came from them.
https://www.fordbarn.com/forum/showt...56#post1798056
https://www.youtube.com/watch?v=boAThNtv3Qg
https://www.fordbarn.com/forum/showt...33#post1785333
Merc Cruzer is offline   Reply With Quote
Old 02-08-2024, 10:42 AM   #19
petehoovie
petehoovie's Avatar
Old 02-09-2024, 02:13 AM   #20
av8coupe
How do the flasher units handle a mix of bulbs, i.e., led brake/tail light with standard tungsten front turn signals?
av8coupe is offline   Reply With Quote
