Old 11-14-2023, 08:20 PM   #41
sven_andretti
sven_andretti's Avatar
Default Re: Fuel Filter issue
I had used a NAPA 3032 in-line filter for 20 yrs. Around 4000 to 5000 miles the filter would get full and start passing crud and need replacing. A few years ago i picked up a replacement and it just would not flow enough gas. I cut open a new one and an old one and found the new one had twice the filter media. The new one had China printed on it and the old one had US stamped on the end.
sven_andretti is offline   Reply With Quote
Old 11-18-2023, 12:31 AM   #42
henry's 31
Hi Randy:
I agree that under the dash looks a lot better,
Henry' s 31
henry's 31 is offline   Reply With Quote
Old 12-24-2023, 08:42 PM   #43
Safari bob
Can you use an in-tank fuel filter inserted in the shut-off value of a late 31 Model A? I know that they are used in the earlier Model A's when the shut-off valve is inside the car.
Safari bob is offline   Reply With Quote
Old 12-24-2023, 09:07 PM   #44
Big hammer
Yes ! I have in my late 31 Tudor, the filter lays horizontal so be aware it will clog up quicker than the ones that stand vertical
get a bigger hammer tap done
Old 12-26-2023, 10:31 AM   #45
Safari bob
Big Hammer, thanks for replying. I will try to get it to work. I can only get it to dribble the gas slowly, certainly not a flow.
Old 12-26-2023, 08:05 PM   #46
ModelAArmy
I have a late model 31 coupe with indented firewall. I installed the 31 fuel filter kit from Snyders and installed it with pill magnet in bottom of Wix filter. So far it is working fine.
Tom in Texas
1931 Coupe
ModelAArmy is offline   Reply With Quote
Old 12-26-2023, 08:34 PM   #47
Synchro909
Synchro909's Avatar
No WIX and NAPA only sells to businesses here. I use any old cheap filter I usually buy on Temu. At about $US1, they work well and can be replaced whenever needed without any concerns.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
